Oil required for 6.9 suspension
More threads by Michel
3 tonnes of wood/steel/alloy and leather on cross plies and under the control of Commander Malik!! Now it is my turn for palpitations!! :eek:
Of course, you can handle a crash gearbox? You remember where to turn on the petrol? You know how to advance the spark? I suggest you leave the cruise control alone in case you can't turn it off.......
Here we are, the day after.... Sunday morning
I drove the Phantom II and it was marvellous.
I expected a rougher and more rudimentary ride.
But, oh to my (pleasant) surprise, it was very civilised...
Here are some pics...
Yours truly, about to alight from the Phantom
Professor Crump (aka Benz Boy) and Commander Malik (Michel) Note the 690SEL in the background
The Phantom II safely parked alongside the 220S Ponton (note the height difference)
The Phantom in good company
Professor Crump farewelling the Phantom
Des
Australia
how did I miss these pictures???
Please take no offense Michel, you look like a 8 year old boy who has just opened all his Chirstmas presents!!!!
that's great!!!
that's great!!!
No offense perceived Des,
The feeling was pretty close...
The Phantom is one hell of a Majestic Motor Vehicle:eek:
I loved driving it...
It was a pleasure
that's great!!!
What about Professor Crump?
Doesn't he look happy :confused:
Des
Australia
It was a pleasure
Now when you get a few moments please share what it was like and how it compared with your RR?
How does it feel to other 1930's cars, if any you have driven? Or to the Pontons?
Kind Regards
Des
Kind Regards
Des
There is no comparison with a modern-day RR, except the majestic feel one gets from being inside a splendid motor car...
Amazingly the ride is VERY comfortable...
Whether it was when Paula and I were chauffeur-driven around Eastern Creek Raceway by Professor Crump or whether it was when I had the priviledge of driving the Phantom!
Physically driving it is a demanding job.
Non-synchro on 1st and 2nd gears demands constant double shuffle upon gear change. Add to that a gated shifter and you must have extra precise shifting abilities...:eek:
The steering is seriously heavy and the cross-ply tyres don't help ;)
While we kept up with the traffic, I would feel that the Pontons, especially the six-cylinder twin-carburetted variety, would handle the day-to-day traffic in an easier fashion. (they are more than 20 years younger)
well.....he looking more stern and serious
The Professor was in very good spirits...
Although he might have been a touch worried that the Phantom would reside in MY warehouse for a while ;)
Not at all worried Commander; just very grateful that SHE has a warm nest in this cold, wet end day of winter. You are a kind man, Commander. ;)
It's a pleasure Professor and an honour for the rest of the fleet to be in such high company.
Des
Australia
Are more modern tyres available in that size? Or would that be frowned upon in the RR community?
How are the brakes? I imagine it is not very discrete, I know the Bentley was like that, you keep getting the feeling everyone is looking at you.
As far as i know, there are no known radials in that size, but then Professor Crump might prove me wrong :eek:
Serious drums all around.
They seem to stop quite adequately, but I would not want to go racing around the 'Creek' with them...;)
There are no radials made inthis size. There are truck radials that some people fit and they improve straight line tracking but are so wide that they make steering almost impossible. The long term solution is to fit 4WD radials and a power steering kit but that will take some time. Long term will see a complete overhaul and the fitting of power steering, an overdrive and airconditioning. I will have a few more grey hairs before all that is accomplished.
The brake servo runs off the gearbox and is exactly the same system that Rolls-Royce kept on the Phantom until they ceased making Phantoms in the late 1990s. It was also used in Clouds until the end of the series. The brakes require a heavy shove but in a brake test against the CLK they proved to stop in about the same distance. The set up is such that the front can not lock. As soon as the front brakes start to lock the servo looses power from the front to avoid a front wheel skid. The servo also proportions the braking between front and rear depending on the load in the car. Brake fade should be almost non-existent given the size of the drums and the depth of material but it is critical that the system be set up properly and it requires re-setting every 500 miles.
Now for some trivia. When the car was built in 1933 it came with a 3 year, unlimited mileage warranty on all aspects of the vehicle. That included sending a technician anywhere in the world to repair it and sending you home by first class passenger liner should the vehicle not be repairable within a reasonable time. That same warranty applied to the Spirit in 1993. And the best some manufacturers can do now is still 2 years and you have to beat the service department with the leg of a dead lamb to get that....
Oh and by the way, I am assured that the steering will get lighter now that we have managed to repair the Bijou and are dripping oil again (Bijou one-shot lubrication system - lubricates the chassis with SAE30 oil and you give it a pump every time before you drive the car). I suspect a rebuild of the steering box might be in order though, or perhaps even a new one, yes, they are available.
Oversize M100 oil filters Mercedes W116 55
B Oil Changing Mechanicals 19
J Wheel required Articles 6
450SE Help required - engine cutting out Mechanicals 15
chrisp Tools required for basic 6.9 maintenance Mechanicals 15
WGB Offset woodruff keys - number required Mechanicals 4
Des Caption Required Talking Torque 11
