Removal of battery
I am posing this query in relation to my 1989 420SEL. The new battery, according to Invoices, was installed some three years ago, and whilst there appear to be absolutely no problems, surely the time will come when it will have to be replaced. Thus, the question I have is this : Would it be just a simple matter of straight out removal/replace ? Are there any functions on the car that are likely to be affected ? Computer, Radio (non-standard) etc. ?
I would be grateful for any advice. Regards Styria
Hi Styria a aftermarket radio is unlikely to have a pin code so no issues there. They really didnt start that till the 90's as for the engine computer there really shouldnt be a problem with a new battery. The problem is surg related with jump starting not battery replacemen. Geoff
Great advice, one more thing would be to switch off an alarm if fitted and make sure your keys are not in the ignition.
Thanks guys for the info. Not being used to owning a "late" (later !) model than 1978, this had been of some consideration. I take it that the 420s have a computer ? If so, does anyone know its location ? Regards Styria
It is right behind the steering wheel Styria, does an amazing job of controlling the speed, steering and braking, and can also turn on the radio:D:D:D
Seriously, it's under the lh front carpet behind a screw in Steel panel
Please explain ? :) I thought that was the function of my big toe ! Regards Styria
N.B. BTW, you can't be serious ? McEnroe..........
N.B. My God, that was quick. Thanks Helmet.
You use your big toe to turn on the radio:eek:
I might do the same, just how bad was the one you looked at?
.....it takes class to own one....and that's a serious issue in this instance. :D.....and indeed, I have tried to turn on the radio with my big toe - unfortunately, I couldn't find it - the toe, that is. This conversation is getting beyond funny - back to the computer and Citroens.
S Battery Advance Technical Information 6
S Tesla 4680 Battery Technical Information 12
c107 BM2 Battery Monitor Technical Information 5
S Battery cost Articles 4
S Flat Battery Articles 49
S Battery Power Technical Information 7
S Battery Styria Articles 9
c107 Correct battery size for a w111 Mercedes W110, W111 and W112 11
c107 Aldi battery chargers Gumtree/eBay/Facebook Listings 13
Oversize Battery Life Technical Information 47
Michel Battery Drain Mechanicals 52
Styria Battery Wear Indicator Technical Information 0
S battery Technical Information 2
260ebenz 300SE flat battery! Mercedes W126 58
