john erbe
Hoping someone with 6.9 could solve a mystery problem of inconsistent oil pressure by taking note of a couple of items on theirs when they check their oil level, on a car that had been sitting overnight and report back. Do this without starting the car
1) when you removed/unscrewed the cap did you hear that you had broken suction on the resevoir ie there had been a vacuum and (2) what was the oil level reading on the stick. Have a nagging issue with oil pressure and now that I've started to remove hoses and fittings from sump have come up with theory as to why this problem had'nt been there before but only after after they replaced a cracked sump. Thanks
