Ignition switch removal
More threads by mrkozzy
mrkozzy
Never finished
Melbourne Australia
I am looking at the degree of difficulty in removing an ignition switch from the dashboard. It's the ignition switch that I want.
Do I have to remove much (or all) of the dash to get it out, or is the wood panel removable separately?
Thanks in advance.
What series car did you want to remove it from?
Posting the answer publically might put the security of all our cars at risk..... Perhaps a series of PMs from those in the know might be better?? :rolleyes:
mrkozzy
mrkozzy
Never finished
Melbourne Australia
I take your point Mark and you are totally correct.
I look forward to some information via pm from anyone in the know.
In saying that, I am not necessarily looking for step by step instructions, as I could figure it out myself given the time.
I am more looking to the degree of difficulty.
ie; do I need to devote a whole day to this project or can I do it "over coffee"
And to fill you in further, the switch is in a "donor" 116. I have it sitting around for the odd part when needed.
A fellow enthusiast has asked me for the switch as he needs it, and I am only trying to help him out.
cheers
Oversize Ignition Neglect Talking Torque 2
S Electronic Ignition Articles 2
Styria 300SEL - 6.3 Ignition Key Mercedes W108 and W109 5
H V12 Ignition Coils for Sale Gumtree/eBay/Facebook Listings 0
hoddo ignition barrel Mercedes R/C107 5
Styria HOUSTON - we have ignition Exteriors and Body Repairs 13
F Ignition lock won't budge Mechanicals 6
Martin280s Fixing the ignition Interiors 3
Michel Hazard Warning Switch Gumtree/eBay/Facebook Listings 2
S heater decides not to switch off Mercedes R/C107 2
260ebenz Electiric seat switch Mercedes W126 12
300SDude Dead Window Switch Interiors 4
Styria Switch panel Interiors 2
BenzLover Re assembling the electric seat switch! Mechanicals 4
