79 280SE
Did some more testing.
Looks like my cold control pressure is way too high
also looks like my fuel pump is on the way out as it gets very noisy after a while. Will replace that first.
Why do you need a cold engine?
I'm testing cold control pressure as my theory is my warm up regulator is the culprit.
engine has to be totally cold, and warm up regulator power disconnected to watch the readings change first when engine is cold and then as it heats up.
As an update on the 280SE, I’ve made good progress and it’s first outing may end up being the MBCNSW 50 year anniversary of the S class event. The w116 waa the first official S class so it would be good to bring the car to that event.
It’s now riunning pretty well. Having the WUR cleaned seemed to have made a big difference.
I still have an issue at below 1/3 of a tank, looks like there is some debris blocking the little hole in the swirl pot but I can live with that for now.
Isle is a bit high - I think I have a vac leak somewhere as the idle screw is right down. I can live with it for now.
I did some temporary repairs on the exhaust system last night. Good enough that it doesn’t sound like a crop duster anymore. While I was in the USA I had the steering coupling changed.
I’ve also removed the broken aftermarket antenna. I’ve mounted a new one but not wired it up yet. At least it looks neat now.
Next I have been cleaning the carpets. Carpets were in good shape but a little dirty. Doesn’t look like much improvement from the photos but they are better.
Before:
The car also had floor mats from another car that didn’t fit. I had some mats from my 560SEC that are a little worn but the right colour. Since the w126 is basically a second generation w116 I hope they fit. I gave them a good clean too. Certainly a lot of dirty water came out. 20870E34-AE37-461E-B726-508CE6BEB0EC.jpeg
On Saturday I need to give the car a good wash, install the mats, check tyre pressure put in a full tank of petrol and take it for a test drive.
it still needs an oil change, SLS rod, drag link, new tie rod end, drivers seat bottom repair and some other misc stuff.
As well as the baby Bissell that Bryce also has, I also have one of these which does extract a lot more;
On the way to the s class event in the 280SE, it’s first outing and only the 3rd time I’ve driven it on the street.
Last night I wired up the antenna, reinstalled the carpets and floor mats, checked tyre pressures, changed all fuses, washed the car, refueld and took it on an extended test drive. Seems ready for the event.
FA749778-A971-4A2C-BEC8-05BC79665C74.jpeg79F7962C-0D72-41F2-863F-F927FB3D0DAA.jpeg3BC19794-A4BB-41F3-9E12-A5BCFF79F06F.jpeg
Obviously you would have seen the 280SE made it to the show. The engine ran well and the idle actually settled down to where it should after more driving.
I'm not going to drive it far until I fix the tie rod end and drag link. Will also check steering shock and idler arm while I'm at it. I got some quite bad vibration through the steering column at various speeds due to these parts being worn.
I'm also going to remove the drivers seat and fix/reinforce the drivers seat too, as it obviously has a couple of broken springs and it's sagging and generally uncomfortable.
Then there is of course the exhaust.
Other things I noticed was that the sunroof is slow and a bit unwilling to open and the rear drivers side window does not work. Speedo is also quite optimistic, like most old benzes.
Original becker works but the on/off doesn't seem to and since I can't turn it off, I can't lower the (new) antenna and park it under the hoist.
Did the drag link, idler arm and all four tie rod ends.
Idler arm looked a bit old and sorry, glad i did it, it was pretty bad when it came out.
Only one tie rod really needed doing, but its not that big a deal to do both sides while I am there, and since I have to pay for an alignment, rather do that once.
Helps to have the right tool. trying to do this without the ball joint separator is a huge pain and it wasn't even very expensive. Bought it a few years ago when I was helping my brother do the 280CE tie rod ends that failed his rego.
2022-07-17 13.51.46.jpg2022-07-17 14.43.53.jpg2022-07-17 15.20.01.jpg2022-07-17 16.04.44.jpg2022-07-18 20.53.13.jpg2022-07-18 21.55.19.jpg
more here:
the 280SE had a wheel alignment done after I did all that work on the tie rods and is now at a muffler shop to have the rotten exhaust system fixed.
The 280SE moves from being a garage queen to a rolling restoration now.
Exhaust is fixed and it drives reasonably well once warmed up.
Next couple of things include fixing the drivers seat and replacing the thermostat so it can warm up faster.
More here:
That is a neat job. I see you went to Hi Tech in Darloinghurst - they have been my go-to exhaust people for 30 years and they have always done a great job.
Yes, they have done four systems for me and always looked after me and done a great job.
A bit out of my way, but worth it for the result.
More here:
Bryce, can you share what the cost of that exhaust was?
Another job done, drivers seat springs fixed.
Untitled by Bryce Dunn, on Flickr
Great documentation on your website!
You’re certainly a man of many talents 😁
after successfully getting the car back on the road I have suffered a setback.
I went to take the kids to a playground in the 280SE this morning, but the ignition key would not turn in the lock. After 20 mins of trying, we gave up and took my wife's modern car.
This afternoon i've been trying to get the lock to turn, so I could replace the tumbler. I've tried all the things on the various kent bergsma videos to no avail. after two hours of trying, I can't get the key to move to position one.
It's currently blocking my other car, so I'll have to go and get some jacks and try and push it out of the way.
If I can't get the key to move, I can't replace the tumbler and I'm stuck.
J Distributer for early 280SE d-jetronic version Articles 4
K 280SE For Sale - 1978, 89,000kms Gumtree/eBay/Facebook Listings 1
6.9forever UK 280SE for sale. Exceptional condition. Websites and Links 8
260ebenz 1975 280se $29,990? Gumtree/eBay/Facebook Listings 10
6.9forever 280SE when new in 1975 Mercedes W116 5
BenzBoy 280SE for sale Gumtree/eBay/Facebook Listings 6
CraigS Australian built 280SE station wagon Mercedes W116 1
260ebenz 280SE for sale Gumtree/eBay/Facebook Listings 11
G Citrus Green 1976 280SE Gumtree/eBay/Facebook Listings 6
Styria 280SE 3.5 Convertible Road Tests 1
260ebenz Time warp: Review 1972 280SE 3.5 Road Tests 2
260ebenz Top dollar for a 280SE convertible Gumtree/eBay/Facebook Listings 7
M [NSW] Wrecking W116 280SE Gumtree/eBay/Facebook Listings 0
260ebenz 1971 280SE 3.5 Cabriolet- $250,000 Gumtree/eBay/Facebook Listings 4
300SDude 1975 - 1980 MERCEDES 450SEL 6.9 PARTS W116 280se AMG 450se Gumtree/eBay/Facebook Listings 3
260ebenz Impressive looking 1970 280SE 3.5 W111 for sale Gumtree/eBay/Facebook Listings 3
motec 6.9 Nice 280se Mercedes W116 11
motec 6.9 Supercharged 280se Mechanicals 2
260ebenz 1971 280SE W111 Convertible Gumtree/eBay/Facebook Listings 4
motec 6.9 Nice 280se Mercedes W116 9
Tony66_au 280SE Info please Mercedes W116 21
motec 6.9 w116 280se shannons Gumtree/eBay/Facebook Listings 10
S 1978 280SE in mint condition for sale in Sydney Gumtree/eBay/Facebook Listings 4
BenzRbest W126 280SE central locking issues Mercedes W126 2
BenzBoy W108 280SE wanted. Gumtree/eBay/Facebook Listings 0
K WANTED - W116 280se in good Condition NSW Gumtree/eBay/Facebook Listings 1
BenzBoy Rather nice 280SE Gumtree/eBay/Facebook Listings 4
B W126 1984 280se Gumtree/eBay/Facebook Listings 0
Styria 280SE Coupe Talking Torque 4
B 280SE with a Lexus V8 transplant Mechanicals 23
450SE 280SE & 350SE for sale Gumtree/eBay/Facebook Listings 10
SELfor50 MY280 - 280SE for Sale. W126 Gumtree/eBay/Facebook Listings 3
116Benz 280SE & 280SEL for sale Gumtree/eBay/Facebook Listings 9
M Where can the starter be found on 280SE? Mercedes W116 1
R Grille part wanted for my '77 280SE Gumtree/eBay/Facebook Listings 4
B Manual 280SE Motorsports 2
B 280se? Mercedes W116 1
SELfor50 W116 - 280SE (400 SE) - For Sale Gumtree/eBay/Facebook Listings 7
L 280se 3.5 Gumtree/eBay/Facebook Listings 7
B FS: 1979 280SE in South Aust. Gumtree/eBay/Facebook Listings 3
s class 280SE - mysterious brake? problem Mechanicals 7
I 78 280se Mercedes W116 1
B W126 280SE - what is it worth? Mercedes W126 8
