Removing fuel tank from a 280se 1977
More threads by Daz
Daz
Bateau Bay
Hi all
Recently I purchased a one owner 1977 280se in great condition for its age. It has been sitting in the owners garage for 5 years, and although she cranks over, it will not start. Understandable of course! I would like to start cleaning all the fuel lines and flush the tank out.
How is the tank removed so I can clean it out as the fuel left in there does not smell the best and I assume there will be a fair amount of sludge!
BenzBoy Removing tint Interiors 11
Oversize Removing hood pad 560SEC Mercedes W126 7
L Removing Adhesive from Painted Panels Exteriors and Body Repairs 6
J Removing dents without panel beating Exteriors and Body Repairs 9
6.9forever #4811 6.9 fuel consumption Mercedes W116 5
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
