Water Leaking problem fixed
More threads by BAR
Thought that I'd share this discovery with the forum members.
I have had a big problem with water coming into the car for some time and thought that it was coming in from the fresh air box. Many have suggested that there is a possibility that the section under the wipers could have rusted and water finding its way into the car from there.
That in fact wasn't the cause.
I had the windscreen replaced 3 years ago and after some very careful inspection and playing around with a hose I discovered that the rubber seal wasn't properly replaced.
Having reset the seal and also applying a tiny amount of silicone windscreen sealant to help it stay in place, the water leak has been cured.
Excellent news....
Nothing more frustrating than a leaking car....:rolleyes:
Well a leaking boat would be too....:D
S water circulating ? Articles 10
S water on Brakes Mechanicals 3
S heater water temp. Mercedes R/C107 8
A water pump Mechanicals 7
L Water Pump Flow Rate Mechanicals 19
Oversize W116 Cabin water entry Mercedes W116 4
hoddo water/methanol injection Talking Torque 4
Styria 6.9 water pump housings Mechanicals 1
BenzBoy Water loss alarm. Mechanicals 4
A Water Leaks Mercedes R/C107 7
B Water in boot and reconnecting drain pipe Mechanicals 8
M The Chronicles Of Mercules - Water Pump Mechanicals 12
Styria Leaking front screen Exteriors and Body Repairs 10
Styria Leaking Rear Struts Technical Information 34
P gauge problem Interiors 7
S Wiring Factory Problem Articles 2
S Styria's wax problem Interiors 3
S washer timing problem Mechanicals 10
S Air con. problem 280SL 107 '81 Mercedes R/C107 5
Styria Steering Box - problem solved Technical Information 21
D Problem with 3.5 w109 Mercedes W108 and W109 2
mycar450slc problem with key/door lock Mercedes R/C107 14
G D-Jet cold start problem Mechanicals 4
WGB Houston - we've got a problem Interiors 5
s class 280SE - mysterious brake? problem Mechanicals 7
O 280 S problem areas? Mechanicals 8
E REALLY... REALLY Need HELP for W108 280SEL 3.5L Idle Problem Mechanicals 8
