D-Jet cold start problem
More threads by GreaseMonkey
G
GreaseMonkey
My '75 280SE takes a while to start when cold, cranking for ten seconds, then fires and runs great, no problem when warm.
Any guesses?
Where do I find 'thermotime switch'?
Or any cold start accessories?
Any clues chaps?
Thanks,
Chris M.
Do you get a nice audible BZZZZZT from the fuel pump for 1 second before you turn the key from On to Start? If its not properly pressurising the system at that moment there won't be enough fuel pressure to push fuel out the injectors while cranking... it may take a few seconds (10 or more) to dribble enough fuel into the plenum chamber and finally give the cylinders something to fire.
Just my 2c worth.
G
GreaseMonkey
Well the fuel pump is not as noisy on this one as some, but I suspected that because if I leave the ignition on for ten seconds before starting, it fires up ok.
Maybe the pump is just tired and needs a while to get up to pressure.
Can I use a fuel pump from a later '80 model 280E?
Are they interchangeable?
Anyone know?
Chris M.
AAB
Toorak Vic
Grease,
I think that you have to check that the fuel pump operating pressures are similar.
My 450 has a " cold start " switch that has been known to give me problems, both for not operating, & recently, for not shutting off.
Plays hell with the mixture & fuel economy if it does not shut off.
Alex
How good is your battery? A fully charged battery with a good earth can make a very big difference in starting a Mercedes.
Styria Testing K-Jet Injectors Technical Information 23
Michel D-Jet, K-Jet, etc... Mercedes W116 8
Styria K-Jet Injector problems Mechanicals 14
BenzBoy How to start yr Benz on a cold morning... Articles 22
B Rough running when cold (6.9) Mercedes W116 1
s class Cold Galvanization Mechanicals 4
S Stop/Start Articles 0
Michel Hard to start Mechanicals 15
Oversize Did this start the 6.9 Legend? Articles 0
S Stop/ start Technical Information 3
mathew M116 won't start Mercedes W126 58
s class Don't start investigating if you don't want to find problems Talking Torque 4
L Preparing to Start a Car that Hasn't run for ~4 Years Mechanicals 12
