Wiring Factory Problem
Where would we be without the Internet.....
Our 204 C Class 2010 70ks car had a modified Rear Light Cluster wiring replaced under Warranty, a known issue back in 2010. Problem has returned as the Mercedes fix was a band aid. They will still repair it, as the plastic of the connectors melts. The Ground wire can't handle the current draw. But I need to jump through hoops to get them to even acknowledge the issue. Much simpler to solder on a heavy:( extra ground wire from the Cluster to the Body Earth connection. A half Hour Job and a permanent fix.
Problem fixed. I knew it was an Earthing problem as all the lights in the cluster were affected. As we are all aware the negative battery terminal provides the Currant i.e., the Electron flow is - to +. For the wiring diagrams it does not matter. They were established before it was discovered that the Electrons flow the opposite Way. Too hard and too late to change. :)
Glad to hear it's sorted
T Dash board wiring Articles 40
WGB 6.9 wiring diagram - Early and Late Models Technical Information 1
WGB 6.9 wiring diagram - Early and Late Models Technical Information 2
S VW Factory Websites and Links 3
WGB Factory reconditioned exchange 6.9 motor for sale? Gumtree/eBay/Facebook Listings 37
Des Poor mans pullman - 300D factory limo Talking Torque 2
Des This is how a W116 should have left the factory Interiors 15
P gauge problem Interiors 7
D Problem with 3.5 w109 Mercedes W108 and W109 2
WGB Houston - we've got a problem Interiors 5
O 280 S problem areas? Mechanicals 8
