Need Steering Wheel
More threads by Michel
I am in need of an 'early' steering wheel for a 116.
By early, I mean small diameter.
Must be in decent condition. (not worn)
Thanks
Does anyone have a spare steering wheel (small diameter) in decent condition?
Michel, you may be searching for something that doesn't exist, as I cannot think of a small Mercedes steering wheel until after the the W126's.
You may have to go to one of the 'pearl finish' steering wheel makers and have them modify a standard W116 wheel to a smaller diameter.
OzBenzHead
Byron Shire NSW Australia
I assumed that Michel was referring to the smaller diameter of the splined shaft and the corresponding hole in the wheel centre, not the size of the wheel itself.
Indeed... I am sorry for not explaining that I was referring to the diameter of the spline which increased in late 1976 to a larger size.....
Thanks Gordon...;)
Oversize Anyone need some Pentas?? Gumtree/eBay/Facebook Listings 6
marie_70 Need help for w109 016 300sel/8 6cyl Articles 32
260ebenz 6.9 they need saving Mercedes W116 16
Des This is what you need in your life Talking Torque 12
Des This is what you 6.9 guys need Gumtree/eBay/Facebook Listings 2
