Wooden Steering Wheel With BOSS KIT
More threads by SELfor50
What's the steering wheel diameter Cam?
Don't have a tape measure here dude. I'll measure it tonight. I think it's about 35cm. It's smaller than a 116 stocker anyway.....
Thanks, but can you also measure it in inches, please... ;)
Measurements still coming...... sorry. Will post it later tonight.
"hmmmmmmm..."?? I'm sure it'll look great in a milan brown 6.9! ;)
Aren't all 6.9's burl wood? Steering wheel is Zebrano, going to bit a bit miss matched.
So true...
My Burl wheel is gorgeously matching the 690SEL
I think it might. Might have to come around and see how it looks in the car :cool:
So? did you get it?
Or was it someone else?
Wasn't me. Didn't get a chance to see how it looked in the car before the auction ended.
This one might be for sale soon;)
That wheel is burl wood isn't it Michel?
Would suit another 6.9 down to the T
Absolutely....
I simply want a bigger one... (diameter..)
An original wheel with wood all around
Absolutely.... it matches perfectly...
However, I simply want a bigger one... (diameter..)
checkout carshine they sell them
I think Styria also can obtain also
Carshine? I'll check..
Yes the Godfather has offered..... we will be talking... :D
thanks Des....
Great pics
In my opinion if the entire wheel was completely wooded, same style as the factory wheel, just with wooden horn pad and the wheel part.
Yes, like the sport wheel I have now.
I agree
problem with that, which I'm sure MB figured out is that if you don't have your seat belt on or somehow hit your head on the steering wheel, it is going to hurt a lot more on wood than soft leather or plastic.
I NEVER drive without my seat belt..
Yes same here, although I do unbuckle when going into a car park, much to the car's beeping protest, find it easier turning my neck to park, I know I know should use the mirrors,
While parking is OK...
I do the same
