Wooden Steering Wheel With BOSS KIT
More threads by SELfor50
SELfor50
Capitown
SELfor50
SELfor50
Capitown
What's the steering wheel diameter Cam?
Don't have a tape measure here dude. I'll measure it tonight. I think it's about 35cm. It's smaller than a 116 stocker anyway.....
Thanks, but can you also measure it in inches, please... ;)
SELfor50
SELfor50
Capitown
Measurements still coming...... sorry. Will post it later tonight.
"hmmmmmmm..."?? I'm sure it'll look great in a milan brown 6.9! ;)
Aren't all 6.9's burl wood? Steering wheel is Zebrano, going to bit a bit miss matched.
So true...
My Burl wheel is gorgeously matching the 690SEL
Ah So; but what will be on your new 280SE/SEL?
:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
Brian, Brian.....
You are ahead of everyone else.....:p
I think it might. Might have to come around and see how it looks in the car :cool:
So? did you get it?
Or was it someone else?
Wasn't me. Didn't get a chance to see how it looked in the car before the auction ended.
This one might be for sale soon;)
That wheel is burl wood isn't it Michel?
Would suit another 6.9 down to the T
Absolutely....
I simply want a bigger one... (diameter..)
An original wheel with wood all around
Absolutely.... it matches perfectly...
However, I simply want a bigger one... (diameter..)
checkout carshine they sell them
I think Styria also can obtain also
Carshine? I'll check..
Yes the Godfather has offered..... we will be talking... :D
thanks Des....
Great pics
In my opinion if the entire wheel was completely wooded, same style as the factory wheel, just with wooden horn pad and the wheel part.
Yes, like the sport wheel I have now.
I agree
problem with that, which I'm sure MB figured out is that if you don't have your seat belt on or somehow hit your head on the steering wheel, it is going to hurt a lot more on wood than soft leather or plastic.
I NEVER drive without my seat belt..
Yes same here, although I do unbuckle when going into a car park, much to the car's beeping protest, find it easier turning my neck to park, I know I know should use the mirrors,
While parking is OK...
I do the same
J 6.9 High Pressure Steering Hose Mechanicals 4
J 6.9 High Pressure Steering Hose Technical Information 1
Oversize Boost Gauge & Steering Wheel Interiors 4
S Steering Wheel Lock Articles 12
BenzBoy Wanted: steering wheel cover information Interiors 2
c107 W123 power steering Mercedes W123 6
S Smaller steering Wheel Mercedes R/C107 13
motec 6.9 New W116 steering box Gumtree/eBay/Facebook Listings 5
Oversize Wood trim steering wheel on Ebay Gumtree/eBay/Facebook Listings 0
Oversize Steering column alignment Mechanicals 6
Oversize Steering Wheel protection Interiors 39
motec 6.9 Nardi Steering wheel Gumtree/eBay/Facebook Listings 2
4 Cutting out on full steering lock Also when heavy braking Mercedes W116 15
mrkozzy Steering wheel repairer Recommended Suppliers 0
Styria Creaking Noise - Steering Box Mechanicals 18
Styria Steering Box - problem solved Technical Information 21
Oversize 6.9 Steering Oddity Mechanicals 3
Styria Fix your Steering Box Technical Information 0
SELfor50 HD Bilstein Shocks, Steering Wheel, Boot Carpet / Rubber & Misc Gumtree/eBay/Facebook Listings 1
Michel Steering Woes Mechanicals 12
Styria 6.9 steering box problems Mechanicals 20
SELfor50 Power Steering Noise (or maybe something else?) Mechanicals 19
WGB Steering Centralisation Mechanicals 5
B Steering groaning when turning right. Mechanicals 14
B 6.9 steering tie-rods Mechanicals 5
J Replacing seals in a power steering box Mechanicals 10
SELfor50 Removing the Ignition Barrel & Steering Lock Mercedes W116 4
B 15 inch steering wheel with OBA large spline Hub. Gumtree/eBay/Facebook Listings 3
Michel Need Steering Wheel Gumtree/eBay/Facebook Listings 7
L Steering Box Question Mechanicals 5
Des AMG Style steering wheel Gumtree/eBay/Facebook Listings 11
Styria Steering Wheels and Instruments Interiors 17
B Steering Box replacement Mechanicals 8
Des Steering wheel question(s) Mercedes W116 21
B Steering Idler-arm bushes - how do I replace them? Mechanicals 3
WGB Steering Spindle Ball Joint press tool Mechanicals 2
Styria Steering Failure - saved by providence Mechanicals 28
s class W140 parking brake, upper control arms, steering assistance Talking Torque 0
SELfor50 Steering wheel boss kits Interiors 11
Michel Nice Steering Wheel Gumtree/eBay/Facebook Listings 2
Michel Steering Wheels -Timber/Leather Recommended Suppliers 22
Michel Mercedes Steering Wheel Gumtree/eBay/Facebook Listings 3
Oversize How to calculate wheel offset Technical Information 4
Oversize Wheel cleaning Exteriors and Body Repairs 1
S wheel swop 17 inch for 18 inch Articles 2
