Bosch injectors and fuel lines fitted to 6.9
More threads by motec 6.9
Hi guys i have the first photos of the bosch injectors and fuel lines fitted to my 6.9 also have the photo off my custom made extractors fitted still having problems uploading photos if anyone could help me it would be apprecietated :eek:
Hi Motec 6.9, I am not 'the computer guru' on topklasse, but perhaps the system I use may assist you in posting your pics. BTW, I did get your phone picture/message, and just a brief comment regarding the hose clips you are using. They are the type that "bite" into your fuel hoses. My recommndation would be for you to contact Wurth Australia and get a supply of their clips - they have no serrations and do not cut into the rubber.
Okay, posting photos, my way - there could well be better systems, but Photobucket is the one I use. So, you need to:
1. Download Photobucket - it's free. 2. Transfer your camera/phone photos to a file you need to create. I call my file "My Pictures", and store it in "My Documents", using Photo/Scanner wizard. Now your photos are in your system.
Next, open 'topklasse' and just create a thread or add to a post. On your task bar, left click to keep the site 'open'. Now open the 'Photobucket' programme and it will encourage you to 'upload your phots/images. Left click onto that prompt, and search for your photos in the 'My Pictures' file. Once your pictures are up, left click one picture, or if you wish to post more than one, hold 'control' and select all pictures you wish to submit.
That prompts Photobucket into action, and it will upload them into its filing system. Once 100% 'Completed', the pictures you have uploaded will be there for you to see. Now 'left click' photobucket on your task bar, so both topklasse and photobucket can be brought into action whenever so necessary.
To now transfer a picture from Photobucket to Topklasse, left click the bottom of four options under the picture, and left click 'copy'. Now open your thread/post in topklasse by left clicking topklasse in the task bar. This will show you your post, and then right click on a blank space under your text which will bring up a small dialogue box. Left click 'paste' and that should then show your picture once you click onto 'reply to post'. Hope all this works for you. Regards Styria
N.B. If anyone would like to add to this, or effect some improvement in whatever way, please feel free to do so.
Hi Motec6.9 -I am not surprised - Cameron's instructions appear to be far simpler, but maybe between the two, you should be able to get there. Anyway, if you have problems, don't hesitate to ring. Regards Styria
Hi guys just letting you know that i have taken my spare manifold over to trg at cannington to have them mod to fit 100mm throttle body from ls3 as i would like to have tps fitted to the throttle body and not on the linkage as has been done car will be going to trg on 13th off April to have final tune up as Kwinana Performance can not tune motec computer will post results as soon as i can:D
Hi guys just a quick update my 6.9 went to tr&green this morning will update as soon as i know about the dyno results and the fittment off larger throttle body have asked for battery to be relocated to the boot doing a lot off phone work as im now in the middle off the indian ocean for the next couple of months:D
Hi guys i still have not figured out how to post pics but i have uploaded pictures off the bosch injectors fitted to my 6.9 they are in the mechanical gallery please be aware that the clamps have been changed since the photos were taken:)http://www.topklasse.org/forums/umg.php?m=45
Oversize Bosch Non-resistor plugs NLA? Mechanicals 0
260ebenz Bosch wipers Talking Torque 0
260ebenz Bosch wiper blades Mechanicals 0
BenzBoy Bosch Websites and Links 0
BenzBoy Bosch Mechanicals 2
BenzBoy Early Bosch Websites and Links 0
B Bosch reproduced old parts - D, K, KE jet Mechanicals 3
SELfor50 Bosch K-Jetronic Mechanicals 6
S Electronic Injectors Articles 3
mercdz M116/M117 D-Jet injectors Mechanicals 0
mrkozzy v8 D-Jet injectors on ebay Gumtree/eBay/Facebook Listings 2
S dribbling injectors Mercedes R/C107 7
Styria Testing K-Jet Injectors Technical Information 23
SELfor50 FS: 1 x M100 (6.9) Modified Intake Manifold & Injectors Gumtree/eBay/Facebook Listings 7
6.9forever #4811 6.9 fuel consumption Mercedes W116 9
abl567 Fuel starvation issues with my 6.3 Mercedes W108 and W109 27
A fuel tank Mechanicals 3
