79 280SE
This is a thread about my new 280SE. My first step is to change the plugs as its running poorly. As I said in the other thread, I don't plan to keep it long term, but to try and tidy it up over a couple of months and fix a few minor issues it has.
However, I am impressed by some of the other things I saw on the car.
1) The wood is in almost perfect condition. I'll take some better photos when I have the car out in the sun.
2) The parchment MB tex interior and carpets are really nice too.
3) Somebody has done regular, routine maintenance on this car. The front calipers look like they have been rebuilt and the brake hoses have 2016 stamped on them. I bought a new set last year and they had 2018 on them, so that makes me think these hoses are pretty new. The diff mount looks quite new and the rear cover has been sealed. All the vacuum lines look in good shape. Fuel pump and filter look new. Accumulators for SLS look like they were changed in the not too distant past. The radiator looks like its been out and re-done
4) The condition of the body is excellent. Paint is in great shape and no rust I have seen so far.
5) It still has the original becker, which works
6) it has good service history until about 2000. First two owners in Sydney until mid 80s and then a long term owner in Melbourne until 2000. I have a thick stack of receipts and the original service book.
7) it is optioned up with sunroof, cruise control, power windows etc. 2021-12-03 08.32.00.jpg
2021-12-02 23.06.00.jpg2021-12-02 22.03.14.jpg2021-12-02 22.34.59.jpg2021-12-02 21.45.20.jpg2021-12-02 21.44.55.jpg2021-12-02 21.20.19.jpg2021-12-02 21.15.03.jpg2021-12-02 21.13.37.jpg2021-12-02 21.13.29.jpg
Now the not so good.
1) Needs a tune up
2) Steering coupler is worn and needs to be replaced
3) rear muffler has been replaced with a stainless unit, but the pipes where that connects to the centre have a few holes and there are another couple of holes in front of the centre muffler
4) SLS rod needs replacing
5) A/C not working
6) drivers seat base needs sorting out. Probably a couple of broken springs
7) shift bushings need replacement
Assuming the tune sorts out the running problems, none of these things are too bad. The muffler could get expensive though.
I won't fix the A/C, but will try and attend to the rest of the list.
2021-12-02 21.13.53.jpg2021-12-02 21.39.42.jpg2021-12-02 21.46.38.jpg2021-12-02 21.47.32.jpg2021-12-02 21.47.45.jpg
Nice purchase.
Nice colour.
Nice interior.
Well done!
Changed the plugs and they looked pretty good. In tkaing off the air box there was an almost new Mann filter in there, another good sign.
Figured I should go back to basics - I found a flyer for a 2018 event under the seat, I don't think the car has seen much use of late and there was little fuel in the tank.
Filled up a 25L Jerry can and put it in, huge difference just driving around the industrial estate where I am. was getting better and better.
Posted a picture of the interior, really doesn't do justice to how nice the wood is on this car
The car runs much better after the new fuel, but it seems like it is not getting all the fuel it wants. For example, when I start it up the car, if you give it throttle it stutters and wants to die like its not getting fuel to match the additional air from the throttle.
My next step is to check the fuel supply.
I borrowed a 48mm socket to remove the fuel sender and look inside the fuel tank to see the condition. If it looks ok, i'll just replace the filter and see if that makes a difference. If it looks a bit dirty, i'll check the screen and if its quite bad i'll have to remove the tank for cleaning.
I'm thinking that the extra 25 liters raised the fuel level above some debris around the tank screen, allowing a bit more fuel to get through. These are all easy things to check before I start getting into the fuel injection system anyway.
Good news is the tank is pretty clean for its age. I took the sender out and there was the normal small amount of debris in the bottom of it.
I'll still check the filter and screen as they are service items anyway and worth ruling out. But at least I am not removing the tank which I am happy about.
I found an exhaust Y piece in facebook marketplace while I was in canberra visiting relos over the new years.
Mine is cracked.
This looks like an upgraded design with more meat between the arms of the Y.
I had hoped the fuel tank screen and filter would be all clogged up. they were dirty, but not all that bad. I've seen cars run properly with worse filters for example.
My new screen and hose should arrive soon, so i'll put it all together and see.
2022-01-22 22.23.40.jpg2022-01-22 22.44.58.jpg2022-01-22 22.45.10.jpg2022-01-22 22.49.00.jpg
Bryce,
Did you say the fuel pressure is right?
That is my next test, assuming this does not fix it. Since the filters are basically maintenance items I wanted to change the out first before I started on troubleshooting the system, especially as it felt like the car wasn't getting enough fuel.
Last night I installed the new strainer, a new fuel hose from the tank, and a new petrol filter.
This job is much easier when there is no fuel in the tank!
When I started the car up, it still had the same issues, so I figured I hadn't fixed anything. I drove it around a bit more and it started to get better and better. I actually think I had bad fuel, not a blockage. Anyway, I see these parts more as service items than anything so glad they are changed.
I assume that somebody left crappy E10 in the tank for too long. Or perhaps it was sabotaged at the auction so somebody could get a better price?
more here:
My next step is to find somebody who can repair my exhaust at a reasonable price.
I took my DS out for a drive last night, and had to move the 280SE out of the way.
It started up fine, but when cold it had the same stuttering and lack of power than before.
I didn't have a chance to let it warm up properly and see if it drove properly like it did last time.
What it seems though, is that it's not getting enough fuel during warmup, or perhaps too much air.
I'll need to do more research on this, but perhaps something to do with the air slide or warm up regulator?
Bryce,
I was recommended yeas a go to Carline at Mt Druitt.
Old school guy, has done a couple of good repairs for me, including my Shadow.
Bryce,
My next result is a fuel pressure and delivery test.
I have the gauge set and should hopefully be able to isolate the problem further.
The Manuals do a good job of explaining the various tests, I can do a fuel volume delivery test (I assume this one is probably ok, as it runs ok hot), system pressure and cold control pressure.
Even if I can't fix the issue myself after that I can provide the test results which should save time and money for any potential repair.
Started the testing on the engine, but got the ports wrong on the WUR so will need to re-do.
Unlike on the V8s, the WUR is hiding down at the back of the engine near the transmission. Pretty hard to see:
K 280SE For Sale - 1978, 89,000kms Gumtree/eBay/Facebook Listings 1
6.9forever UK 280SE for sale. Exceptional condition. Websites and Links 8
260ebenz 1975 280se $29,990? Gumtree/eBay/Facebook Listings 10
6.9forever 280SE when new in 1975 Mercedes W116 5
BenzBoy 280SE for sale Gumtree/eBay/Facebook Listings 6
CraigS Australian built 280SE station wagon Mercedes W116 1
260ebenz 280SE for sale Gumtree/eBay/Facebook Listings 11
G Citrus Green 1976 280SE Gumtree/eBay/Facebook Listings 6
Styria 280SE 3.5 Convertible Road Tests 1
260ebenz Time warp: Review 1972 280SE 3.5 Road Tests 2
M [NSW] Wrecking W116 280SE Gumtree/eBay/Facebook Listings 0
260ebenz 1971 280SE 3.5 Cabriolet- $250,000 Gumtree/eBay/Facebook Listings 4
260ebenz Impressive looking 1970 280SE 3.5 W111 for sale Gumtree/eBay/Facebook Listings 3
motec 6.9 Nice 280se Mercedes W116 11
motec 6.9 Supercharged 280se Mechanicals 2
260ebenz 1971 280SE W111 Convertible Gumtree/eBay/Facebook Listings 4
motec 6.9 Nice 280se Mercedes W116 9
Tony66_au 280SE Info please Mercedes W116 21
motec 6.9 w116 280se shannons Gumtree/eBay/Facebook Listings 10
S 1978 280SE in mint condition for sale in Sydney Gumtree/eBay/Facebook Listings 4
BenzRbest W126 280SE central locking issues Mercedes W126 2
BenzBoy Rather nice 280SE Gumtree/eBay/Facebook Listings 4
B W126 1984 280se Gumtree/eBay/Facebook Listings 0
Styria 280SE Coupe Talking Torque 4
B 280SE with a Lexus V8 transplant Mechanicals 23
450SE 280SE & 350SE for sale Gumtree/eBay/Facebook Listings 10
SELfor50 MY280 - 280SE for Sale. W126 Gumtree/eBay/Facebook Listings 3
116Benz 280SE & 280SEL for sale Gumtree/eBay/Facebook Listings 9
M Where can the starter be found on 280SE? Mercedes W116 1
B Manual 280SE Motorsports 2
B 280se? Mercedes W116 1
SELfor50 W116 - 280SE (400 SE) - For Sale Gumtree/eBay/Facebook Listings 7
L 280se 3.5 Gumtree/eBay/Facebook Listings 7
B FS: 1979 280SE in South Aust. Gumtree/eBay/Facebook Listings 3
I 78 280se Mercedes W116 1
B W126 280SE - what is it worth? Mercedes W126 8
