6.3 Transmission removal
More threads by abl567
The transmission in my 6.3 has had a slight leak ever since I bought it, when driven daily it used to reduce to a drip every other day so it was never really a problem however reduced use would result in a larger loss. Of course it gradually got worse until the car was simply undriveable, 2 litres every 10km:eek:
2 minutes idling produced this leak
The only solution was to drop (more on that later) the box and and renew the seals in the box and fluid coupling.
Time to put my hoist to good use
I removed the tailshaft, exhaust and other bits and pieces in no time at all, then, as the manual shows the 6 bolts that hold the coupling to the back of the crankshaft.
Time for the heavy work so with the help of a very experienced fellow (Thanks Styria) we removed the fluid cooler lines, remaining bell housing bolts and a few bits and pieces then started to drag the box back to allow it to drop down, no matter what we did the coupling would not come back with the box:confused:
Then I discovered the last 2 bolts holding the coupling to the crank, M100's have 8, not six as shown in the manual:eek:
With these removed and an hour wasted we finally lowered the transmission hoist and the tranny was clear and ready to carry to the bench.
Instead we dropped it on the floor:rolleyes::rolleyes:
I'm not really sure how we managed it but all of a sudden it started sliding off the hoist past the point of no return. We sort of had hold of it so instead of free falling it rolled to the floor and by the grace of god didn't suffer any damage of land on our feet:p
Talk about a comedy of errors.
With the box on the floor we removed the fluid coupling, front pump and valve body.
Styria check the band clearences which were within spec and took away the valve body and front pump to clean and replace the seals and I took the coupling to Torque Convertor Industries just around the corner who replaced the seals and add 2 additional O-rings then pressure tested it.
They only took 3 days and charged $100 less than the quoted price:D
The box will hopefully go back in on Wednesday.
In the mean time I have degreased underneath the car to remove the muck and gunk that was left after Styria wiped most of it off into his hair:eek:
He said it took 10 washes to get it all out, luckily I'm a bit shorter then him;)
I also adjusted the hoist so it can lift about 2 inches higher to clear his scone.
Stay tuned for the next comical episode
J 8HP Transmission Swap Mechanicals 4
abl567 Wanted T350 Transmission Gumtree/eBay/Facebook Listings 4
S Transmission Kick Down Articles 2
S Transmission Mercedes W116 1
B 10-Speed Transmission Websites and Links 3
S drain plug Transmission Mechanicals 5
R 450SE harsh transmission shifts Mercedes W116 15
motec 6.9 722.300 Transmission Manuel Mechanicals 41
300SDude Transmission Question Mechanicals 3
Oversize 6.9 Transmission Upgrade Mercedes W116 76
MercedesMike 6.9 Transmission Pump Mechanicals 8
WGB Automatic Transmission Manual Part 1 Technical Information 1
Michel V8 Mercedes Engine and Transmission complete Gumtree/eBay/Facebook Listings 0
TJ 450 6.9 Transmission Rebuild Mechanicals 4
J transmission swap Mechanicals 0
abl567 6.3 Transmission howl Mercedes W108 and W109 15
s class W140 driveline/transmission issues Mercedes W124, W201, W140 and R129 7
Michel Complete Engine And Transmission in Victoria Gumtree/eBay/Facebook Listings 4
S Paintless Dent Removal Exteriors and Body Repairs 1
H Igntion Barrel removal Technical Information 14
Oversize Rust removal by electrolysis Exteriors and Body Repairs 1
WGB Instrument Cluster removal 101 Articles 3
mrkozzy Ignition switch removal Interiors 4
L Dashboard Removal? Interiors 4
L Power Window Removal Technical Information 1
L Sunroof Frame Removal Technical Information 1
Styria Removal of sunroof frame Interiors 5
Styria Removal of Instrument and Switch Panel Interiors 10
Styria Removal of 6.9 Master Air Cell Mechanicals 1
Styria 6.9 removal of heads Mechanicals 32
s class Paintless dent removal Exteriors and Body Repairs 4
s class Att Lukas : ceiling trim removal Interiors 5
L W116 Sunroof Removal for Dummies Technical Information 42
