M110 280 motor
More threads by Terqel
Terqel
MELBOURNE
hi all,
can someone tell me please if you can adjust the valve clearance on the M110 280 motor.
I have noisy tappets and given that it is an twin OHC configuration I have reservations.
many thanks
Sure can! You'll need a special 17mm spanner so you don't dislodge the rocker retainer spring. I used to do this all the time when I worked for MB, but it was a long time ago.... I'd either adjust them when the engine was hot, or stone cold (overnight) & I'd use a jump lead to spin the engines so the rocker arms were positioned correctly. I think they were set to 0.04mm (inlet) & 0.10mm (exhaust) when hot from memory. Be very carefull you don't round off the adjusting nuts, because they can be tight, the hexes are narrow & they'll be covered in hot oil! :eek:
Hi Mark, am I correct in assuming that the special spanner you refer to is in fact a Medrcedes Benz tool ? Or alternatively, could it be purchased from an outside supplier, such as Snap-On or Stahlwille ?
Terquel, without that spanner, you're not in the hunt ! Getting back to Mark (Oversize), I have always been under the impression that tappet clearances were adjusted with engine stone cold - that's how I have always carried out adjustments on the M100 (6.3) engines. You might have some thoughts on this subject matter. Regards Styria
T
Terqel
MELBOURNE
thanks for the info, I feel better now. I will follow up on the special 17mm spanner and give it a go.
regards
Hi guys, we had settings for hot n cold. It's obviously not practical to only have cold settings if you're required to service a car & it's just driven off the street. It was pretty rare to keep them overnight unless things got more involved. I was careful to make sure the engines were one, or the other & nothing in-between. If I was setting them hot, I'd make sure everything was ready to go & I'd even pre-dissasemble some components if I could, to allow me to remove the rocker cover/s quickly. I think the settings were 0.06mm / 0.10mm hot & 0.04mm / 0.10mm cold. The larger clearances were for the exhaust. Yes I believe the spanner was available through Stahlwille; I'm sure it'd be far cheaper than the MB equivalent. Then again unless you're a dealer I doubt MB would sell you one. :mad:
BTW I found it much better to adjust them cold as you didn't have to worry about the engine cooling down and more importantly, you didn't burn yourself! :D
:D...good thinking Number 1. Rocker covers on 6.3s aren't the easiest to remove, especially the one on the passenger (left) side - again, you have to ask yourself why the Company couldn't have put a little more foresight into planning disassembly procedures - you know, the large bracket that holds the coil, the metal breather pipes for the two rocker covers, the high tension leads.......I am sure you know all about it. Regards Styria
....oh, I forgot the Air Con hoses !
QLD6point9 Free m110 injector holders x8 Mechanicals 1
motec 6.9 SSK replicar with m110 Talking Torque 1
M First time pulling an engine (m110) suggestions? Mercedes W116 11
G M110 motor - yours for FREE ! Gumtree/eBay/Facebook Listings 0
Des A question for M110 owners Mercedes W116 6
Des Some thoughts on the M110 engine(s) Mechanicals 13
Michel Cheap VRS Kit for M110 ? Gumtree/eBay/Facebook Listings 1
S 280 Coupes Gumtree/eBay/Facebook Listings 2
L Manual 280 with "Extras" Gumtree/eBay/Facebook Listings 1
carl888 1974 280 se w116 Mercedes W116 14
A FS: Mercedes-benz 280 SE (1978) requires new loving home Gumtree/eBay/Facebook Listings 0
motec 6.9 Nice 280 se coupe for sale Mercedes W110, W111 and W112 3
S 280 SL cruise control Mercedes R/C107 3
300SDude 1968 280 SL Turbo Diesel Gumtree/eBay/Facebook Listings 3
300SDude OMG! BEAUTIFUL1966 Mercedes 250SE / 280 SE Convertible W111 Gumtree/eBay/Facebook Listings 5
Oversize A couple of 280's for sale in NSW Gumtree/eBay/Facebook Listings 1
B Tested out the aircon and cooling on the 280 today>>>>> Mercedes W116 9
B For the manual 280 fans: engine + box $250 starting bid Gumtree/eBay/Facebook Listings 20
O 280 S problem areas? Mechanicals 8
SELfor50 1 Hour To Go! [280 SE - VIC] Gumtree/eBay/Facebook Listings 5
SELfor50 W116 280 SL for sale?! Gumtree/eBay/Facebook Listings 3
c107 Poor quality genuine motor mounts Mercedes R/C107 9
J Motor for W114 Compact 250 1970 Mercedes W114 and W115 2
c107 British Motor Museums Car Show Photos 7
B 6.9 starter motor Mechanicals 5
Styria Bremen Classic Motor Show Websites and Links 5
260ebenz Detroit Motor Show Articles 1
Styria 2012 Detroit MOTOR SHOW Talking Torque 9
A v12 motor from w140 Gumtree/eBay/Facebook Listings 19
motec 6.9 Motor Drive SL500 Road Tests 4
Styria Starter Motor Rebuild Articles 1
