Just before the M100 rally the fuel injection pump on my 6.3 started to leak internally and overfill the govenor part of the pump, this results in rich running and oil running out of the pump filler tube into the valley of the engine and then onto the driveway or the hot exhaust when you plant your foot. I cured the symptom for the rally by running a oil bypass line from the injection line filler tube to the dipstick tube, needless to say that got me through the rally but it was time to fix it properly.
I decided to install the spare pump I bought from a M100 club member many months ago so today removed the existing pump, it wasn't that hard really, no that is a lie it was bordering on self harm but worth it
Some pics
Left inlet manifold, injectors and injection lines. the parts in the bottom of the box are the throttle linkage
The empty valley
Old pump
New pump ready for install
This is all the fastners I had to remove to get this far, it is unbelievable how well designed these cars are.
Some pics
The empty valley
Old pump
