Transmission Question
More threads by 300SDude
300SDude
Hunters, WA. (USA)
so.......my W116 started only topping-out at about 40 when going up hills (I live in the mountains). I took it in to my mechanics and a hose had come-off the turbo. They re-attached it and everything worked well again. (It hasn't had an issue for about a year, but I don't drive it all winter).
Today I drove it to the casino and back (30 miles round trip), and I have to have it floored to get up the hill, and it's back to topping-out at 40 again. I checked the turbo, and everything seems to be attached OK.
Since I have had it, when you try and punch (floor) it from a stop, it tends to slip a little between first and second gear, but if I start-out normally, and gradually pick-up speed, it shifts just fine. Is this a major transmission issue?
Not that I am trying to burn rubber in my diesel, but when my partner drives it, she doesn't like the way it shifts and picks-up speed from a stop.
I guess I am just a pansy and just drive my baby slow wherever I go, lol. It doesn't really bother me the way it shifts, but is it something I should have looked into, or is something simple?
Thanks for any advice.
300SDude
It could be many things. Are you getting full throttle? Get one of your girls to floor it when the engine's off to check the linkages. Why did the hose come off? If it's gone hard it could've split somewhere else....
What's the colour of the trans oil like? When was it last serviced?
300SDude
300SDude
Hunters, WA. (USA)
I've never done anything with the transmission, or the oil in it. It's red, that's about all I know, lol.
300SDude
It would probably be advisable to change the transmission oil and filter. You might also have a look at the adjustment of the Modulator valve - if it is out of adjustment, you can get slurred shifting of the gears. Regards Styria
abl567 6.3 Transmission howl Mechanicals 15
300SDude Hubcap question? Mercedes W116 6
mrkozzy Radiator treatment question. Mechanicals 3
G Vacuum advance retard question Mechanicals 2
G Colour change question Exteriors and Body Repairs 8
G Speedo stripes? Dumbest question this week? Interiors 20
Des A question for M110 owners Mercedes W116 6
Des maybe the "obvious question" for the day Talking Torque 2
Des Question(s) for BenzBoy and Michel Talking Torque 12
Des Question on lights on race cars Motorsports 18
B HVAC Question Mechanicals 0
Des Sump plug question Mechanicals 16
BenzBoy Engine question. Talking Torque 16
Des question on doors Exteriors and Body Repairs 15
