Gentlemen,
May I seek your collective wisdom and advice about as car that comes from a place other than Stuttgart?
The car in question is a 1966 Daimler 250. That is, the small Daimler V8. I am having some difficulty assessing the following:
25,000 miles since 1966 - one owner - motor smooth and just a hint of tappet noise. Oil pressure at hot idle a fraction below 15 lbs per square inch - a fraction above 20 lbs per square inch on the move - but run the engine with the oil filler cap off and there is slight fumimg.
No smoke at start up or under accelaration. I ran the motor hot and took off the oil filler cap and got slight fuming - let it stand for 30 minutes and got the same - but it was not smelling of burnt oil. There were a few drops of condensation on the inside of the cap. Oil clean (changed last in Dec 07) and the radiator fluid showed no signs of oil contamination.
What do you think?
What do you think?
