PvD
Mountain Dweller
I have been trying to overcome the poor starting when my 6.9 engine hot and has been standing for more than a few minutes. The possible causes are the non-return valve near the fuel pump, the accumulator, fuel vapourisation, etc which all come to inadequate fuel an pressure when stating the engine hot. I have installed a push button to allow the fuel pump to run when I start the hot engine. The engine running signal to keep the fuel pump running after the engne has been started is operated by the air flap (refered to as dummy lid) switch in the air intake, thus if the engine stops running for any reason the fuel pump stops. I initially wire the normally colsed push button in the wire between the air flap switch and the earth, this did not work because the air flap switches uses an internal connection to the engine as earth (auto elecetics are confussing). Now that I have rewired the normally closed pushbutton in the other wire to the air flap switch I can now run the fuel pump with the ignition switch on by pressing the normally closed push button.
I'am trying various durations to use this push button when the engine is hot, has any body found the optimal time to run the fuel pump before operating the started motor to get an immediste start?
Peter
Peter
