M117 - Engine shake at idle
More threads by 6.9forever
6.9forever
My 117.985 engine in the 450SLC idles quite smoothly at the specified 750 rpm and normal temp (87C), but it shakes and vibrates the body (e.g. sitting at traffic lights). Is this an engine mount problem or other?
Look forward to members' expertise.
Thanks.
Are you in neutral for the smooth 750rpm idle and transmission engaged at the lights when the shaking and vibration occurs?
6.9forever
6.9forever
In Drive, with foot on brake at lights, Anthony - shudder occurs. Revs go up when in Park or Neutral. In P or N I'll re-check what happens with shudder.
6.9forever
6.9forever
Yep shudder is there when stationary in P, N or D. Just a bit rough, not smooth even though revs look healthy.
Hi 6.9 forever, initially I would start checking high tension leads and suppressors. As well, how about spark plugs - how old are they. Maybe this is a car that's not being used much and has probably never had a lot of time spent on its mechanicals and state of tune. Regards Styria
6.9forever
6.9forever
Thank you for the "lead" ... (get it?) LOL. I'll make some investigations.
SELfor50 M117 Engine Gumtree/eBay/Facebook Listings 3
c107 AC Compressors for the M116/M117 and 6.9 Mercedes W116 5
c107 M117 450 - Worn Rocker Arms Mercedes W116 3
Oversize C111 Epic Soundtrack M117 TT Motorsports 6
Oversize Sbarro Twin Turbo M117 Talking Torque 0
Oversize M117 Burnout Websites and Links 3
motec 6.9 Gemballa w126sec m117 6.9 Talking Torque 2
Tony66_au M117 wont idle Mechanicals 4
SELfor50 M117 Piston Gumtree/eBay/Facebook Listings 0
Des M117 Tuning Motorsports 7
WGB M117 450 - 370bhp Motorsports 25
SELfor50 M117 Gearbox Gumtree/eBay/Facebook Listings 4
J Engine bay detailing question Exteriors and Body Repairs 3
S Same Engine Articles 14
