M117 - Engine shake at idle
More threads by 6.9forever
6.9forever
Sunshine Coast
My 117.985 engine in the 450SLC idles quite smoothly at the specified 750 rpm and normal temp (87C), but it shakes and vibrates the body (e.g. sitting at traffic lights). Is this an engine mount problem or other?
Look forward to members' expertise.
Thanks.
Are you in neutral for the smooth 750rpm idle and transmission engaged at the lights when the shaking and vibration occurs?
6.9forever
6.9forever
Sunshine Coast
In Drive, with foot on brake at lights, Anthony - shudder occurs. Revs go up when in Park or Neutral. In P or N I'll re-check what happens with shudder.
6.9forever
6.9forever
Sunshine Coast
Yep shudder is there when stationary in P, N or D. Just a bit rough, not smooth even though revs look healthy.
Hi 6.9 forever, initially I would start checking high tension leads and suppressors. As well, how about spark plugs - how old are they. Maybe this is a car that's not being used much and has probably never had a lot of time spent on its mechanicals and state of tune. Regards Styria
6.9forever
6.9forever
Sunshine Coast
Thank you for the "lead" ... (get it?) LOL. I'll make some investigations.
SELfor50 M117 Engine Gumtree/eBay/Facebook Listings 3
SELfor50 M117 Extractors - For W107 Engine Bay Gumtree/eBay/Facebook Listings 8
SELfor50 LS1 inspired M116/M117 Engine Overhauls!! Mechanicals 1
Oversize C111 Epic Soundtrack M117 TT Motorsports 6
Oversize Sbarro Twin Turbo M117 Talking Torque 0
Oversize Looking for a M117 5.0?? Gumtree/eBay/Facebook Listings 3
Oversize M117 Burnout Websites and Links 3
motec 6.9 Wanted M117 560 throttle body Gumtree/eBay/Facebook Listings 11
motec 6.9 300SE Coupe with 5.0 M117 Gumtree/eBay/Facebook Listings 8
mercdz M116/M117 D-Jet injectors Mechanicals 0
motec 6.9 Gemballa w126sec m117 6.9 Talking Torque 2
Tony66_au M117 wont idle Mechanicals 4
SELfor50 M117 Piston Gumtree/eBay/Facebook Listings 0
Styria What spark plugs for the M117 and M100 Mechanicals 19
Des M117 Tuning Motorsports 7
WGB M117 450 - 370bhp Motorsports 18
SELfor50 M116 Heads on an M117 Mechanicals 17
s class M117 timing chain tensioner help Mechanicals 10
SELfor50 M117 Gearbox Gumtree/eBay/Facebook Listings 4
B 450SE/M117 lower sump gasket - does it need sealant or not? Mechanicals 10
S Same Engine Articles 14
