Pads you recomended and supplied work very well in our 2010 C Class Helmet. No Black Dust etc.
What oil should I use in the 5 speed Auto ?
Now 40000 Ks It has been quirky all it's life, and has had Soft Ware re loaded a couple of time by the Dealer. Now at times only, it is starting to shudder again on up shifts under light/ medium throttle, and under load.
An oil change and Filter worked wonders on my 722-306 4 speed 1981 SL 280'
Life time oil was fop to the Fleet users in Europe to contain running costs.
Mercedes had to back down on that one.
Can I use an upgraded Synthetic Oil,
Graham at Mercedes workshop had told me that the electronics sometimes get confused
I can't pick if it is the lock up CONVERTER OR ONE OF THE CLUTCHES IN THE bOX.
Also is there a drain plug in the Converter ?
I used to drill a i/8 th hole in Comadores and weld them up again for this cost cutting omission.
It was no big deal.
Thanks again......Sean
It was no big deal.
