Top end overhaul.
More threads by aussie 6.9
aussie 6.9
western nsw
With my 6.9 approaching 300km and concern about running hot in the summer I was thinking of doing a top end overhaul and replacing the timing chain guides At the same time.
Who would be the best work shop to do this job?
I have rodded the radiator replaced the water pump ,thermostat ,temp sender , flushed the block, replaced the thermo fan, but in the summer it still runs up around 100c.
My 450sl used to have similar issues but worn valve guides meant I had the cylinder heads reconditioned and it now runs cool in summer and no smoke.
Any advice appreciated.
Regards Mark.
Does the temp drop when you’re on the highway?? Might be the engine fan clutch
Mark, could be a Thermostat issue, but I would suggest that a new replacement core may solve your hot running issues. There is no doubt that Sydney Traffic on a hot Summer's day will test the efficiency and DESIGN of the cooling system, but in the case of my GB, due to some of my efforts, overheating is something I don't have to contend with.
It may perhaps pay to keep in mind that GB is not an Australian Complied car. It differs in having a different Radiator, different Gearbox Internals i.e. without the external pump and additional plumbing that is fitted to Australian and American versions, and having a higher compression ratio of 8.8:1 may perhaps also help with preventing overheating issues.
I have also fitted a genuine flat bellied 350SL first muffler, and coupled it to a straight through high quality, as well as huge stainless steel end muffler. Some of these modifications are obviously non-original, but if they assist in doing the job, I am more that satisfied with what has been achieved. Regards Styria
Just an additional note after reading your remarks on your 450. About twelve years ago (?) I did carry out a Valve Grind and De-Coke task on Gleaming Beauty, and that may have also helped in preventing overheating. Food for thought. Regards Styria
Oversize Top 50 cars of all time! Articles 2
motec 6.9 Jaguar iPace takes top sales honors in Norway Articles 0
Oversize Top Gun 2 Websites and Links 2
Oversize Hydropneumatic Strut Top Mounts Gumtree/eBay/Facebook Listings 4
260ebenz Top 10 Mercedes Benz Myths Talking Torque 8
motec 6.9 BBC Kill Top Gear Articles 12
Styria Convertible Top Care Technical Information 1
Oversize Top Gear S63 vs 6.9 Road Tests 1
260ebenz Top dollar for a 280SE convertible Gumtree/eBay/Facebook Listings 7
BenzBoy TK's top 10 detailing tips for Tim. Exteriors and Body Repairs 220
260ebenz Top Gear- Maserati vs Mercedes C63 AMG Talking Torque 0
M Q: R&R of Hydro Strut Top Mount? Mechanicals 11
300SDude Ebay~1961 MERCEDES BENZ 300d "ADENAUER" HARD TOP SEDAN Gumtree/eBay/Facebook Listings 7
Oversize Top Gear 600 vs RR Talking Torque 5
grant v W116 with Vinyl top Mercedes W116 2
450SE Hard top squeaks & rattles Mercedes R/C107 7
J 107 Soft top on eBay Gumtree/eBay/Facebook Listings 1
A Putting the Hard Top on Exteriors and Body Repairs 22
J Replacing a 107 soft top - photos Mercedes R/C107 0
B The infamous Top Grear Botswana Challange episode Motorsports 2
Des Magic Top Talking Torque 4
Michel The World’s Most Exclusive Open-Top Luxury Saloon: The New Maybach Landaulet Talking Torque 11
Oversize The End of V8 Supercars? Motorsports 2
S A flighty Rear End Articles 9
S Low end Torque Articles 7
B The end of the 6.9 road :-( Gumtree/eBay/Facebook Listings 8
BenzBoy Styria's rear end? Mechanicals 3
WGB Pictorial - Rear End Rebuild - Final Assembly Technical Information 0
4 450SEL front end rattle Mercedes W116 25
WGB 6.9 Rear end rebuild - Pictorial Mechanicals 4
Styria complete 6.9 rear end on ebay Gumtree/eBay/Facebook Listings 5
B Team116 #2: front end tart-up on 450SE Motorsports 8
G W116 Front End Wobble ? Mechanicals 7
SELfor50 New front end Exteriors and Body Repairs 3
WGB 6.9 strut overhaul - take 2 Technical Information 5
WGB 6.9 Strut overhaul Technical Information 20
