The use of ATF in your fuel
Hi Des, just very quickly on something you obviously are not aware of - our good friend JohnS is no longer with us. Getting back to ATF, I would suggest that nothing will save a tired and worn out engine. BTW, that pussycat you're hanging on to - your Avatar reminds me of the character with the cat in "From Russia with love" - if you don't believe me, have another look at your Avatar. :D You couldn't get closer. Regards Styria
BenzBoy Current MB recommended ATF fluid changes Talking Torque 10
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
