Steering wheel question(s)
More threads by Des
my thoughts on car safety relate to a few items that you don't mess with:
Brakes and Steering.
Without them you have no control...
Definitely have an expert check out your steering. Because of the high caster angle with 116's the steering should always want to return to the straight ahead position. You would need a very high toe out angle to make it want to steer into the corner more. Are your front tyres wearing on the inside edges?
