Smaller steering Wheel
Any advice on sourcing and the viability of fitting a smaller steering to my '81 107 SL would be appreciated.
I have read that the reason for the large 18 inch wheel is that in case of a power steering failure the driver can still have some control of the car.
So I figure a 15 inch wheel should be ok for easier driving ????
New wheels are not cheap,.. and all being well I would like to try and find a used one
I wonder if others are having trouble opening Topklasse ?
I keep getting a notice saying " Page Not Found. "
Only way I can open the site is to Google it and wait.
My Favourites address listings has always worked till now ????????????
Sean, sometimes if you restart the PC, the problem solves itself. I find this quite a lot with Real Player after downloading songs - Real Player just doesn't open up. Regards. Styria
Thanks Styria ,
Problem solved. I've had a simular problem, at times, with our Mobile Phones .
Ours is not to reason why !
hoddo
northwest sydney
Sean one of the reasons for the large wheel design is so you can see the instrument panel properly through the top opening in the wheel. A smaller wheel will obscure your view.
I have had the engine cut out in the fast lane heading west on the M4; I was at the speed limit of 110km/hr.
No engine*, no power steering!!
I'll tell ya, it was a frightening experience!!
THAT'S when you need a BIG steering wheel.
With about 1.3 tonnes over the front wheels, it perhaps not surprising WHY, with a 6.9, that power steering is essential.
Even so, you need to have the muscles of a gorilla to keep control.
* The engine failed due to a faulty fuel pump relay; the fuel delivey pump from the tank just stopped working.
Replaced the relay with a four pin type. Cost? Nil.
Benefit? The engine starts on first compression every time!, but that can mask the problems of a weak battery.
It IS still possible to start a 6.9 on first compression every time with the standard 5 pin fuel pump relay: just crank the engine in gear first, the engine won't start in gear, BUT the fuel pump WILL nevertheless bring the fuel system up to pressure; that takes about four seconds. Switch the starter off, then put the transmission in park or neutral, and start the engine. Voila!
I reason that Mercedes, in their wisdom use a five pin relay, so that if there is a minor fuel leak, and the engine is hot, that there is a slightly less possibility of a fuel fire.
Yes ,we modify Mercedes at our peril. The wisdom of friends have persuaded me as to the error of my ways ! !
Still having a hard time logging on even with Goggle Chrome.
A job for Son in Law.... a Microsoft service Engineer .
Love the small steering wheel.
I have one on the 690SEL and also on the 500SL AMG.
They do obscure the speedo, but it's worth the hassle.
What logging problems??? :eek: :eek:
Just sent an email to Son in Law....... and wouldn't you know, the site is now ok ? It's been down all day.
Would it be possible to have a look at your small steering wheels Michel ?
Thanks Sean
Thanks Sean
This wheel is on the 690SEL
This is the one on the 500SL AMG
I am amazed both of the small steering wheels are not well you guessed it red Michel!
:D
Thanks for the pretty pictures Michel... they look good.
Where did you get them ?
Did they come with a Boss to fit the splines ?
I understand that this can be a problem , both obtaining a Boss and having the correct splines.
Thanks Sean
I hate not seeing the speedo and tach so it's a bigger wheel for me....
Thanks Sean
The brown one was on a 450SE I bought without an engine/box
The black one is part of the AMG package that was fitted to the 500SL.
You find them on eBay often
http://www.ebay.com/itm/Mercedes-AM...Parts_Accessories&hash=item51c1d43af9&vxp=mtr
http://www.ebay.com/itm/Mercedes-sl...Parts_Accessories&hash=item27e6cf1cf5&vxp=mtr
J 6.9 High Pressure Steering Hose Mechanicals 4
J 6.9 High Pressure Steering Hose Technical Information 1
Oversize Boost Gauge & Steering Wheel Interiors 4
S Steering Wheel Lock Articles 12
BenzBoy Wanted: steering wheel cover information Interiors 2
c107 W123 power steering Mercedes W123 6
motec 6.9 New W116 steering box Gumtree/eBay/Facebook Listings 5
Oversize Wood trim steering wheel on Ebay Gumtree/eBay/Facebook Listings 0
Oversize Steering column alignment Mechanicals 6
Oversize Steering Wheel protection Interiors 39
motec 6.9 Nardi Steering wheel Gumtree/eBay/Facebook Listings 2
4 Cutting out on full steering lock Also when heavy braking Mercedes W116 15
mrkozzy Steering wheel repairer Recommended Suppliers 0
Styria Creaking Noise - Steering Box Mechanicals 18
Styria Steering Box - problem solved Technical Information 21
Oversize 6.9 Steering Oddity Mechanicals 3
Styria Fix your Steering Box Technical Information 0
SELfor50 HD Bilstein Shocks, Steering Wheel, Boot Carpet / Rubber & Misc Gumtree/eBay/Facebook Listings 1
Michel Steering Woes Mechanicals 12
Styria 6.9 steering box problems Mechanicals 20
SELfor50 Power Steering Noise (or maybe something else?) Mechanicals 19
WGB Steering Centralisation Mechanicals 5
B Steering groaning when turning right. Mechanicals 14
B 6.9 steering tie-rods Mechanicals 5
J Replacing seals in a power steering box Mechanicals 10
SELfor50 Removing the Ignition Barrel & Steering Lock Mercedes W116 4
B 15 inch steering wheel with OBA large spline Hub. Gumtree/eBay/Facebook Listings 3
Michel Need Steering Wheel Gumtree/eBay/Facebook Listings 7
L Steering Box Question Mechanicals 5
Des AMG Style steering wheel Gumtree/eBay/Facebook Listings 11
SELfor50 Wooden Steering Wheel With BOSS KIT Gumtree/eBay/Facebook Listings 19
Styria Steering Wheels and Instruments Interiors 17
B Steering Box replacement Mechanicals 8
Des Steering wheel question(s) Mercedes W116 21
B Steering Idler-arm bushes - how do I replace them? Mechanicals 3
WGB Steering Spindle Ball Joint press tool Mechanicals 2
Styria Steering Failure - saved by providence Mechanicals 28
s class W140 parking brake, upper control arms, steering assistance Talking Torque 0
SELfor50 Steering wheel boss kits Interiors 11
Michel Nice Steering Wheel Gumtree/eBay/Facebook Listings 2
Michel Steering Wheels -Timber/Leather Recommended Suppliers 22
Michel Mercedes Steering Wheel Gumtree/eBay/Facebook Listings 3
Oversize How to calculate wheel offset Technical Information 4
Oversize Wheel cleaning Exteriors and Body Repairs 1
S wheel swop 17 inch for 18 inch Articles 2
