Monthly fuel price check
Well it's certainly been a mixed bag over the last 6 months... LPG went through the roof, but it's now more than reasonable (comparitively). So at the Sunbury BP yesterday:
91: $1.309
95: $1.399
98: $1.439
LPG: $0.527
BTW I noticed the Bulla BP selling LPG for $0.499 and with the $0.020 discount (with a BP autogas rewards card) it'd be $0.479!! That's a bit nicer....
It also occurred to me it might be a good idea to update this thread each month, as a snapshot of the market and to try to prevent any of us getting ripped!!!
Thanks Tim, but it doesn't seem to work for us here in Vic
Hi Tim fuel watch is WA only its another failed Rudd/Gilard scheme but it works a treat for us over in the West . Geoff :D We had it before Rudd announce it to roll out around Australia .
A fuel tank Mechanicals 3
