Fuel starvation issues with my 6.3
More threads by abl567
Great it's going good now , maybe good to think about having the inner tank lined with a rust proof coating
Do you mean like the POR-15 tank treatments Helmet? I've heard they can block the inlets and outlets and interfere with the function of the swirl pot?
Great to hear its running again Ant. Sunday cruises back on the agenda .:D
Looking forward to it Geoff, as soon as you have a ETA let us know
Started 6th week of medical this week 18 week duration before getting clearance. :D
And people wonder why they go out of business!!! Do it right the FIRST time! I dunno how many things I've had re-repaired... And they have the gall to call themselves 'professionals'! Drives me nuts! :confused::(:mad::eek:
After being stung in the past. I now check with prior customers before committing to work. :mad:
I guess the real lesson here is to always go back to first principles and fully explore every avenue even if "but I've fixed that" runs through your mind
6.9forever #4811 6.9 fuel consumption Mercedes W116 9
A fuel tank Mechanicals 3
P Fuel For Post July 1976 116 models Mechanicals 22
