Fuel For Post July 1976 116 models
More threads by PeterR
FYI 1L metho to 20L petrol is 5% alcohol & 2L is obviously 10%. Another downside is you’re no longer referred to as a petrol head; you shall now be known as a meth head!! Lol
I guess unless you can get it 30% cheaper than 98, it’s false economy due to the higher consumption rate
I would not use E10 in a classic. The ethanol plays havoc on all the fuel hoses, diaphrams etc. It also promotes rust in the fuel system.
We are incredibly lucky that we can still buy proper petrol in 95 and 98, in some places you cannot and you can read about all the problems it causes for classics. This is the case in many parts of the USA and in the UK.
This is not the case for modern cars as they are designed for it.
c107 Old Fuel Mechanicals 24
A fuel tank Mechanicals 3
