280SE Info please
More threads by Tony66_au
280S Info please
Ive stumbled on a 280S locally, it is a 75 model according to the current owner and he is keen to get rid of it.
it was a daily driver but has now been sitting for 5 years, shedded.
He says is has a 4 barrel carb, is that correct?
the car also has 500'000 ish km
What can I expect?
Thanks,
Tony
I think the 'E' indicates that it should be injected..... :rolleyes:
With half a million Ks, don't expect much....:rolleyes:
A little more info.
Went and had a look today, its a 280S, MB Tex/Cloth inserts, sunroof, carb'd and manual windows.
Can someone decode the plate please as i only had literally 5 mins to look before i had to shoot off.
The car was a daily for 5 years and then parked after a new car came along, the car has been where it sits now for a further 5 years.
My son gets his license in 12 months and loves the 450's but can not drive them as they are a V8 so i thought this may be suitable, Jenna also likes it.
LOL yeah I had a quiet chuckle when i opened the back door.
Im thinking parts or sons car and a few hundred dollars.
I take what I said back... :eek:
I love barn finds like this one.
PLEASE don't scrap it. :eek:
Your son will thank you for it.
Thats ok Michel I didn't take it to heart mate :D
This find came about because of a chat with a local I know who was rationalising his cars and had been agonising over the Benz.
I reckon its worth a shot and time will tell what she ends up being as I haven't told my Son yet.
The weird thing?
It was the colour and the hubcaps that grabbed me, and the car screams Wedding car...........
Now if I could only remember how to go about getting an SV license for the car.......
So Im taking the old girl and I'll give her a cleanup and park her in the sun awaiting Alex's reaction.
If he wants to drive it then he can but she will belong to me until he can show me he is capable of looking after her.
That and I can full comp insure her and make sure everything is correct.
From my cursory inspection she has no rust and how hard can a Carbed 6 cylinder be to maintain?
Or are they famous last words? lol
BTW do these things have SLS?
Hi Styria, yes I had a look after my post and realized it was there. However the option code list is not..... :rolleyes:
Hi Mark, apologies for not reading your post properly. Regarding the option codes - it would probably be somewhat unethical on my part to utilize the other crowd's facilities. I will work out something in the end, but not from their source. Regards Styria
Yeah I was thinking along similar lines and I wonder where the information was originally sourced? Always better that way, just in case there's been errors during transfer..... :rolleyes:
Tony you may have probs with the carb since it's been dry for so long. It might pay to find an expert on these and put a kit through it. I doubt it'll have SLS. Absolutely awesome if it has no rust! Hope the rats haven't eaten all the wires!!! :eek: It might pay to have a look.... (pics as well). To me it screams manual conversion!!!! Haha!
thanks for that!
Im going to very carefully do some prep before turning the key, my usual routine involves upper cylinder lube into the cylinders plugs out ofcourse but this time in using Inox, I also drain the oil and chuck a cheapy filter on and then fill with a high zinc content oil (Nulon high mileage in this case which is a 20/50)
I leave the oil to drain for a day or so at an angle that encourages sludge escape.
I'll drain coolant fluids from the block and system and refill accordingly and I will have on hand a roll of Silicone blue heater hose and top/bottom rad hoses.
Drain fuel tank and check for rust or paint flake and refill with Caltex Vortex 98 (A Non E10 fuel)
Add workshop battery and once the engine is filled with fluids again I will crank slowly listening for nasties with the plugs out, give it another spray with Inox and then crank till oil pressure comes up, then add plugs and check carby for weeping or leaks and see if she fires or tries.
When I took the pics BTW I had a sniff for rodents (got a good nose mate) and i looked for tell tale signs under the bonnet too and it looked clear.
the Ghost who services euro cars In Meeniyan that our esteemed member from Bass coast mentioned also serviced this car and his work is evident in the quality hoses and MB parts stickers on a few bits and pieces.
So now its a suck it and see exercise I guess.
it'd be nice to be minus SLS I guess and i will check when i get my grubby hands on her but first things first.......
A thorough hand wash AND if she scrubs up ok maybe even a wax!
Why?
Coz im weird, and because Jenn is far more forgiving about immobile objects if they are Shiny :D
Ta for the tip on the carb BTW.
Tony
Well, I must admit that I'd have some trepidations buying a car in this condition. Maybe if I was twenty years younger, I might consider it but nowadays ? No, I'd be worried that I would be able to do justice to the car. Regards Styria
What was playing on my mind when I first heard of this car was that id been looking at W123 280TE's and that spare engine bits wouldn't hurt and considering I have 2 other S class Benzes other bits would come in handy.
Then I had a quick look, checked the underside of the doors for rust and a bit later was told of the service history and decided that for a few hundred dollars it was too nice to go to scrap.
Considering scrap prices currently sit near $800 a ton if I was to strip it then id get my purchase price back on the shell alone.
I make no bones about it being an emotional decision either and remembered all the godawful wedding cars ive driven over the years and envisioned the car gleaming with White ribbons lol
Ive also just started to come out of a long cash drought Styria and because Ive been good with my car spending cutbacks and this household being more than fairly democratic (it helps having a wife who likes old cars) my disposable income level allotment went up from Nothing to something usable.
this means a real Mig, concrete floors in my huge shed, a rewire and a 2 post hoist and some better tools so Id best have some stuff to play with lol
I also have a very good long time friend who had Panel shops for years and is a "Gun" painter with his project as proof which takes care of the one area I am lacking in being Paint and Panel.
So Id be mad to not have a few options.
So the resto order is as follows for now.
Lili goes first as she is by far the best.
then depending on the condition of the 280 the 280 is next on the slab.
The brown 450 has issues and is currently off the menu but not to the scrap for bits stage until Ive had another look at her so she is in dry storage.
All cars in the barn on a sand pad till the floor is laid, windows slightly open and my rodent bait stations are showing me no new nibbles now for a month so i think ive got the mouse issue licked and I am no longer cutting or buying hay so that should make sure the mice stay away lol
Hi Tony, all very good, but how are you controlling the cattle and the horses ? :D More to come as at the moment I am just trying to be funny ! Regards Styria
N.B. BTW, nice to know you're in the money. :)
LOL Funny bugger eh?
Got rid of the cattle BTW, saw the current issues comming a mile off and swithed to sheep.
I was horse free until a few weeks ago when my Mother in law flew in and retired her old horse here so we can rehome it grrrrrr
c107 79 280SE Mercedes W116 93
K 280SE For Sale - 1978, 89,000kms Gumtree/eBay/Facebook Listings 1
6.9forever UK 280SE for sale. Exceptional condition. Websites and Links 8
260ebenz 1975 280se $29,990? Gumtree/eBay/Facebook Listings 10
6.9forever 280SE when new in 1975 Mercedes W116 5
BenzBoy 280SE for sale Gumtree/eBay/Facebook Listings 6
CraigS Australian built 280SE station wagon Mercedes W116 1
260ebenz 280SE for sale Gumtree/eBay/Facebook Listings 11
G Citrus Green 1976 280SE Gumtree/eBay/Facebook Listings 6
Styria 280SE 3.5 Convertible Road Tests 1
260ebenz Time warp: Review 1972 280SE 3.5 Road Tests 2
M [NSW] Wrecking W116 280SE Gumtree/eBay/Facebook Listings 0
260ebenz 1971 280SE 3.5 Cabriolet- $250,000 Gumtree/eBay/Facebook Listings 4
260ebenz Impressive looking 1970 280SE 3.5 W111 for sale Gumtree/eBay/Facebook Listings 3
motec 6.9 Nice 280se Mercedes W116 11
motec 6.9 Supercharged 280se Mechanicals 2
260ebenz 1971 280SE W111 Convertible Gumtree/eBay/Facebook Listings 4
motec 6.9 Nice 280se Mercedes W116 9
motec 6.9 w116 280se shannons Gumtree/eBay/Facebook Listings 10
S 1978 280SE in mint condition for sale in Sydney Gumtree/eBay/Facebook Listings 4
BenzRbest W126 280SE central locking issues Mercedes W126 2
BenzBoy Rather nice 280SE Gumtree/eBay/Facebook Listings 4
B W126 1984 280se Gumtree/eBay/Facebook Listings 0
Styria 280SE Coupe Talking Torque 4
B 280SE with a Lexus V8 transplant Mechanicals 23
450SE 280SE & 350SE for sale Gumtree/eBay/Facebook Listings 10
SELfor50 MY280 - 280SE for Sale. W126 Gumtree/eBay/Facebook Listings 3
116Benz 280SE & 280SEL for sale Gumtree/eBay/Facebook Listings 9
M Where can the starter be found on 280SE? Mercedes W116 1
B Manual 280SE Motorsports 2
B 280se? Mercedes W116 1
SELfor50 W116 - 280SE (400 SE) - For Sale Gumtree/eBay/Facebook Listings 7
L 280se 3.5 Gumtree/eBay/Facebook Listings 7
B FS: 1979 280SE in South Aust. Gumtree/eBay/Facebook Listings 3
I 78 280se Mercedes W116 1
B W126 280SE - what is it worth? Mercedes W126 8
