Hi all,
I recently drained the cooling system of a 450, and was able to flush both the radiator and the engine with a garden hose. This is after disconnecting the top and bottom radiator hoses, then adding water in either direction at the top opening.
When I tried this with a 6.9, I couldn't flush the engine - presumably there was insufficient water pressure to get past the water pump, and/or the pump has a different design that blocks the flow when the pump isn't moving.
My back-yard-hack solution was to run the engine, let it pump the water out of itself, and constantly refill with clean water via the surge tank. This worked well, except that:
1) It sprayed rusty water everywhere: as the water comes out of the hose, dribbles onto the fan and get splattered everywhere.
Extending the top hose with a spare section sorted that.
2) The pump only started working when the engine temp reached about 80 degrees C - assume it has some kind of thermal clutch? I had assumed it was direct drive. What's the benefit of such a setup?
3) When the pump was working, the flow rate struck me as not great - equivalent I suppose to about 2 teapots pouring at once (rusty, steaming brown tea). I worked it out as roughly being about 5L/min. Is that the normal flow rate, or is the pump worn?
Regardless of the above, it worked well and there is now nice clean coolant in there.
Ta
Ta
