Has anyone ever removed this 'dry sump' tank from their car ? Believe me, it's one of those jobs that can be quiote cumbersome and physically demanding. The tools required, primarily, are Open End spanners ranging in size from 36 millimeters down to 27.....
and it5 is necessary to remove the front valance in order to gain access to the oil hoses that run from the tank to the small enginesump containing the oil pump.
It will take you all your strength to undo those large fittings. I almost felt like giving up. Invariably, and almost essential, one needs to use two spanners - one to undo the fittings, and with the other to support the fittings on the tank. Regards Styria
