Oil viscosity.
More threads by BenzBoy
A very scientific Paper Brian... not for the faint hearted... never the less a clear message.
A friend, in the Motor Trade, successfully negotiated an Engine rebuild on his Daughters 4 year old VW Golf. He was able to demonstrate that the correct VW Spec oil had been used. Apparently there is a special blend to alleviate a weakness in the design/material build of the Turbo/super charger units. I checked the VW Specs for my Turbo Golf and found that a number of Oils now meet VW requirements. Full Synthetic 5/30 or 40 in warm climates ( Here ) Biggest surprise was the variation in prices asked.
By a wide margin was German sourced , Fuchs. OEM to " Mercedes" also BMW and VW.
$35 Trade for 5 litres, from Silver Star Spares in Kingsgrove.
Sean, are you suggesting that $35.00 is all one pays for five litres of Fuchs Synthetic ? If that's so, that's a bargain. Fuchs - obviously a German word, but does it really come all the way from the Fatherland ? Regards Styria
Has been manufactured here to German Fuchs Technologically for 100 years.
Titan SuperSyn Labelled "Special Longlife Technology"
Specifications
ACEA A3/b4.......API SN/CF
Approved ... VW 502 00/505 00 ............ BMW.... Porsche.. etc
Used exclusively in the Work Shop of Silver Star Spares ( Euro Parts ) ,who specialise only in European Cars
There is a lot of information on the Net.... haven't found a negative word about the Product.
Proof of the Pudding Styria...... order a couple of 5 litre containers ... they will deliver for a few Dollars. Just give them your Trade name ie., Motor Repairer and a credit card. They won't ask questions.
Sean
B Oil Changing Mechanicals 19
