Fitting new rear brakes to 107
Hands up as who has done this job ? By that I mean fitting new disc rotors, reconditioned calipers, new brake pads and new handbrake shoes. Anyone ? Please come forward and let me know what you think of the job - your observations, degree of difficulty, time etc. I would be most interested to know. Regards Styria
G
GreaseMonkey
Not on a 107, but I have done that on a 123.
I think, from what I have seen on mine, most components are the same or similar, in which case, no problem, except remember my oft mentioned preference for pressure type bleeders over the vac type.
You may have to back the handbrake adjusters off a fair bit, to get the drum/rotor off.
Chris M.
Hi Grease Monkey, probably not quite the answer I was looking for. What I have found is that the whole job is quite straight forward and easy with the exception of removal and replacement of the brake shoes.
I was looking for an easy way to replace those, I was trying to ascertain the amount of frustration in attending to and rectifying an operation that ought to be far easier, and I was also looking for a comparable time factor as far as the overall timeframe of the job was concerned. Regards Styria
Michel Fitting the interior on Bluey Mercedes W116 1
B Fitting aftermarket cruise control? Mechanicals 6
