w107 custom exhaust
More threads by garrye
I intend to focus on extractors for my W116s, which will probably be an engine-out proposition. Once fitted the rest will be easy. Following Styria's lead I'll be using flanges instead of the original slip joints to make disassembly much easier. I once thought dual pipes would be the way to go, but the large diameter single system with a high flow muffler (and cats) on my AU V8 sounds awesome!! :cool: I'm starting to wonder if a larger muffler will tend to give that deep throaty V8 burble that I love so much.... Bigger chamber = an internal echo-like effect??
BTW Blue Flame has a modified exhaust and sounds like a worked big block Chev! And that's WITHOUT extractors! I do intend to use the system fitted to that car as a reference point. Pix to follow when I get to it....
To get back to GarryE's original post - you may wish to have a look at Michel's 500SL AMG - whilst I am not sure, I suspect that his car is fitted with extractors. The exhaust sound is quite, shall we say, intoxicating - just keep on easing off the throttle, and re-apply - it puts a smile on your lips each and every time.
I don't know, Garry, what system you have on your car - I do know that 350s can sound quite roarty - on those, the original muffler is a very shallow affair and, some years ago, I decided to fit a 350 first muffler to GLeaming Beauty. It did eventuate in a slightly more raspy exhaust note, but the large 6.9 end muffler certainly greatly restricted the music coming from the exhaust pipes. Thus, some little while ago, I did away with the huge rear muffler and had Merrylands Exhaust fit a beautiful, straight through item in its place, with straight twin pipes emanating from under the rear apron. A bit like Oversize's muffler system, the exhaust note resembles that of a helicopter (yes, that's right), but it doesn't sound quite as gruff as Oversize's. It certainly is, mind you, somewhat throatier than the system on Michel's Red Terror. Regards Styria
Hi Garrye i would go with Brians suggestion in Sydney of HiTech .But any good exhaust shop should be able to make a good sports exhaust . I would go twin 2 1/4 inch front pipes with front mufflers then into a 2 1/2 inch single tail pipe with a rear muffler . And as soon as i figure out how to post when i have the time i will record my car Mark it sounds like a broadside from the Bismark . It is louder than my VY one tonner it had duel 3 inch pipes with only centre mounted hot dog mufflers a real b&s ute sound . Geoff :D
Yes, that 6.9 of a truck engine, certainly produces its own, distinctive note. To be sure, it is a somewhat gruff engine, not particularly quiet, but the torque produced by what is essentially an outdated design, is quite remarkable. No need to change gears, just plant your foot. Someone though should try changing down to 2nd at about 50 km/hour - the acceleration is remarkable. Regards Styria
garrye
garrye
penrith
Thanks everyone for the input,
My exhaust at present is stock except I removed centre muflers with actually no difference in sound.
Its time to play around again and see what note I can acheive.
If you're trying to get better sound, I would imagine that ther'd be no need for extractors. There is not a lot of space under the bonnet of your 450, and extractors would be quite costly. Better sound - should be easily achieved with appropriate muffler(s). If I were you, I'd still look at Michel's car for guidance. Regards Styria
Hi Garrye as a rull extractors will cost about 300 per cylinder so at least 2500 to make you will not get them for under this i know i have them on my 6.9 :D
garrye
garrye
penrith
Can anyone explain what the cross over pipe is for, as I dont know what it actually does, and is it really needed?
Hi Garrye it balance the exhaust gas with a V8 so you have the same back pressure on both banks. But mainly it stops the exhaust popping and crackling and give a less boomy exhaust sound . Geoff
Not really needed on an original benz as I the dual pipes go into single mufflers where the gasses from both banks are combined.
I'd look at a large diameter single system, as it's difficult to get twin pipes side-by-side to look neat (unless you know a very good exhaust shop). Just get a rear muffler with twin outlets for that original style.
I have exactly that setup on my AU V8 and it still crackles n pops on over-run like a Supercar! It sounds brilliant at 3K rpm and I've been waiting for good weather to shoot a video with some special audio gear.....
On a V8, you can't beat a twin exhaust sound and feel because of the two banks of pistons and because of the 'even' number of cylinders on each side (it's not as nice on a V6).
As long as you have the 'right' back pressure, your car will definitely breathe and go better;)
Phewww
After reading and absorbing that, do I get a certificate of achievement? :D
Wow, that needs serious mechanical and engineering knowledge!!! :eek:
Thanks Geoff, very interesting article... ;)
motec 6.9 Will never buy a W107 Mercedes R/C107 20
Oversize New W107 FB Page Websites and Links 1
260ebenz Something for W107 fans Mercedes R/C107 6
6.9forever R/C107 not W107 Mercedes R/C107 3
Styria Tribute to our W107 Websites and Links 0
WiSeGuYY UTE from w107 slc Exteriors and Body Repairs 13
Oversize The best W107 video??? Motorsports 12
motec 6.9 W107 Mercedes R/C107 3
motec 6.9 w107 with m120 Mercedes R/C107 1
motec 6.9 w107 big block Mercedes R/C107 0
Oversize W116 & W107 pics on Youtube Websites and Links 2
garrye W107 SLC Side skirts Mercedes R/C107 14
Eagle Bill W107 Flasher canister Mercedes R/C107 2
S w116 parts on a w107 Mercedes R/C107 3
T hardtop SL W107 Mercedes R/C107 3
C Which W107 model? Mercedes R/C107 14
T 280SL W107 flasher can location Mercedes R/C107 7
B Wtb: W107 sl parts Mercedes R/C107 0
J W107 Repairs etc link. Mercedes R/C107 0
smueller99au W107 350SLC engine mounts Mechanicals 14
J W107 Subframe Recall Mercedes R/C107 3
J Keyless Entry for W107! Mercedes R/C107 3
Des The daddy of all W107's Mercedes R/C107 33
QLD6point9 Custom reproduction MB decals Exteriors and Body Repairs 2
Oversize Custom Number Plates for sale... Gumtree/eBay/Facebook Listings 0
Oversize Custom SEC Mercedes W126 1
c107 380SEC custom audio setup Mercedes W126 1
Oversize Custom Dashboard Facias Interiors 0
Oversize Custom Interior Mercedes R/C107 0
c107 Custom Ford Mustang Exteriors and Body Repairs 3
260ebenz Custom reserve 450SL Mercedes R/C107 1
B Old School or Custom Paint Exteriors and Body Repairs 0
Oversize Custom bellhousings Mechanicals 1
Oversize Custom throttle bodies Mechanicals 7
motec 6.9 Barris Custom the Rose Talking Torque 5
Oversize Blue 450SL custom Gumtree/eBay/Facebook Listings 1
S freeing up exhaust Technical Information 11
260ebenz How to: Sand back & repaint exhaust tips Exteriors and Body Repairs 15
Oversize US 6.9 exhaust systems Mechanicals 7
