Repair a broken seat spring
More threads by John S
Ahemm.....
Well it got him out of trouble..
For a while... :eek:
That doesn't quite look up to Parks' standards...
It doesn't allow the spring to act as a torsion bar as designed but it does stop the end from flapping around.
I was faced with this prospect last weekend with one broken spring when I added some padding to my drivers seat.
I know that welding or brazing will affect the temper so I did a similar fix using some old steel fuel line from my 1938 Ford V8. I cut a much longer length than he used (the full length of the straight broken section) and forced it over one end, pulled the other broken end laterally until it slipped into the tube and then crimped the tube with vice-grips to stop it from slipping off either end.
Looks a little more elegant than the "tie-wire" method.
I didn't photograph it as the length of fuel line looked pretty ordinary but the seat squab is definitely better supported and easy enough to repair if it ever lets go.
Another option might be to solder a clean new length of tube but crimping at least allows some rotational movement.
I would be interested in Park's opinion on how to repair this common fault.
Parks
you can actually get a tool that crimps a clip around the broken part, there isnt a really fool proof way of fixing the problem so basically solutions like this isnt that bad, so basically whatever works then go for it
You should be able to put some stronger steel around that if one didn't have a crimping tool.
Even using a pair of pliers and twisting the metal around...
J
I have just learnt that you can use a 123 seat base in a 126, mounting holes etc are the same - I wonder if the 116 is similar, or if the 116 and 126 bases will swap across too?
There should be more no sag 126 bases around than 116's, so if they fit it would only mean having to swap the leather across to the "new" base.
Oversize Rust Repair Panels Exteriors and Body Repairs 2
Oversize 300SD Collision Repair Video Mercedes W116 3
S seat repair Mercedes R/C107 5
260ebenz Accident Repair Costs Talking Torque 16
D Minor rust repair / panel beater Melb? Exteriors and Body Repairs 5
J Drivers seat stuck at full height adjustment. Mercedes W116 3
S seat belt holders Mercedes R/C107 4
260ebenz Electiric seat switch Mercedes W126 12
260ebenz Silicone spray seat belts Interiors 13
Oversize Seat upgrade Interiors 2
BenzBoy Advice on how to clean a light coloured seat belt? Interiors 25
WGB Another take on sagging seat bases Interiors 7
Martin280s Seat bases Interiors 6
BenzLover Re assembling the electric seat switch! Mechanicals 4
WGB New rear leather electric rear seat finally sorted. Interiors 6
WGB Delayed but welcome arrival of new rear seat leather Interiors 5
