Rear Parcel Shelf
One common area of deterioration by sun and age relates to the rear parcel shelf on 107's and obviously 116's as well. Parks has recovered one of our member's rear parcel shelf, and also painted the material covered panel that's situated on the interior of the bottom of the screen.
The transformation in appearance is quite remarkable, and even the first aid cover is beautifully reproduced in keeping with the original design. I believe that Hoddo does have a picture of the work carried out on his beautiful 450SLC and hopefully he'll be able to post it on our site. Regards, Styria
hoddo
northwest sydney
yes parks did a great job,
Hoddo, thanks for that - it really does look good - and not only because Parks did it.
bb - you sure can hide it from the outside by tinting the window...but, can you hide it from yourself ? Think about it !;)Regards, Styria
braminator123
Aficionado
Hi Styria,
You said it! That is my archilles heel. I can never hide anything from myself.
Though I keep asking, where does it start and end?
I love daily driving these beauties though I also love showroom fit and finish!
OzBenzHead Rear parcel shelf Interiors 10
Styria New rear parcel shelf Interiors 3
T W116 6.9 HPF spheres: keep front and rear references separate Mercedes W116 2
S A flighty Rear End Articles 9
Oversize AMG Rear Spoiler? Exteriors and Body Repairs 1
Styria Seized rear brake caliper Technical Information 21
motec 6.9 AMG rear spoiler Gumtree/eBay/Facebook Listings 4
BenzBoy Styria's rear end? Mechanicals 3
J W126 rear seat swap Interiors 1
motec 6.9 brabus rear muffler W123/116/126 M110 Gumtree/eBay/Facebook Listings 3
motec 6.9 W116 rear trunk filler Gumtree/eBay/Facebook Listings 11
Oversize Heated rear seat Mercedes W116 11
Oversize W116 Rear spring saddles Mercedes W116 1
Styria Replacing rear handbrake shoes Technical Information 13
Styria 6.9 CLACK CLACK rear hub. Mechanicals 6
Styria Rear Axle drawing Technical Information 1
WGB Pictorial - Rear End Rebuild - Final Assembly Technical Information 0
WGB Advice re Torquing rear hub nut Technical Information 5
Styria Leaking Rear Struts Technical Information 34
K 6.9 Rear Bumper - Bottom One Gumtree/eBay/Facebook Listings 0
WGB 6.9 Rear end rebuild - Pictorial Mechanicals 4
Styria complete 6.9 rear end on ebay Gumtree/eBay/Facebook Listings 5
Styria Unique Rear Brakes - 6.3 Mercedes W108 and W109 7
