I received the new stator shaft and seal kit today.
Then, I noticed something odd... the part that presses into the bore of the bellhousing is a larger diameter on the new unit.
The part number is the same for all 3-Speed 722.xxx transmissions. What on Earth is going on here? The one that was pressed out of the spare 450 trans is the same as the one removed from the 6.9s bellhousing, a smaller diameter. It is an interference fit rather than being clipped in.
It looks as if it may need to be machined to fit.
