6.9 head gasket - part No / where to buy
More threads by CraigS
CraigS
I suspect I have a stuck valve and/or leaking head gasket, so I will pull the head to have a look and check. Anyone have a source for new head gaskets ? Last ones I bought I got from Niemoller and they were cheaper than anyone in the US at the time, but I have lost the part number. Anyone have it handy ?
Hi Craig, are Niemoellers still able to supply ? It is my understanding that Benz are stopping/have stopped after market suppliers from selling 'genuine' parts - a a Reitz gasket, is it genuine ?
I did have some made up locally with good results (a few years ago), althbough I am not sure if they complied with the correct thickness as per the genuine gasket. Sorry I don't have a part number, but they are in excess of $300.00 each from the States. Is it your white car ? If it is, that's less than ideal. Which head is involved - a "stuck" valve should be evident if you removed the rocker covers, but I am sure you know all that. Regards Styria
CraigS
CraigS
I haven't checked with Niemoller as yet, but I suspect it is as you say, unless they have some old stock. All the valves look OK - none stuck, so it looks like it may be the gasket. This is on the red car. Finally getting around to looking at it. The white one is fine.
CraigS
CraigS
Thank you kind Sir !
Looks like the best price I can find so far is US$439.30 for the set, including freight.
Hi Craig i still have the email price from MBSpares when i bought a full gasket set from them just over 2 years ago price was $186 for each head gasket PM your email and i can forward to you or you can phone them Murray on 1300 787 300
CraigS
CraigS
Spoke to MB Spares. After initially quoting somewhere around the $630 mark, they revised the price to a "best we can do $585". Apparently there has been 3 price increases over the past year and this is the result.
Classic Centre price was $284.00 on 17th Dec 2010, that was for a 6.3 and was for the set, not just the head gasket
100-010-09-21 left head gasket set 6.3 $284.00 1 week
100-010-10-21 right " $284.00 1 week
CraigS
CraigS
Can you recall what was in the set ? I presume it was not exhaust gaskets. I hear they are also pretty pricey.
Anyone know what the torque settings are for the 6.9 head ? I want to check it before removing it.
Yes exhaust gaskets are included, as are inlet manifold gaskets, the crush rings for temp and oil pressure sensors, all associated coolant gaskets and o rings, even the gasket for the chain tensioner.
And those prices are list, if you are a member of the M-100 group there is a further 15% discount...
CraigS
CraigS
Sounds good. Will check the 6.9 prices with Tom
Good try, but membership of any Mercedes club will also get you the discount !
Yes, but the M-100 group is dedicated to M-100 owners;)
You mean you haven't asked Tom for a price?
If I remember correctly, the gasket kits do not include the valve stem seals. Regards Styria
Craig, why not let abl567 procure the parts for you - his service is excellent. I don't mind paying a few extra dollars, being secure in the knowledge that the orders are being handled efficiently. Just my opinion. Regards Styria
CraigS
CraigS
Anyone have the part number and/or photo of the special tool for removing the head bolts ?
Do you mean the 140mm long 10mm hex head socket?
6.9forever Head up display and polarised sunglasses Interiors 5
abl567 6.3 Cylinder head work Mercedes W108 and W109 9
J R116 016 Cylinder head on eBay Gumtree/eBay/Facebook Listings 0
Styria Retorqueing 6.9 Head Bolts Mercedes W116 12
Michel W116 sedan rear head rest kit Gumtree/eBay/Facebook Listings 0
B 450SE/M117 lower sump gasket - does it need sealant or not? Mechanicals 10
J Part Search Aide Technical Information 4
Michel part numbers Technical Information 4
J Euro Distributor Part Number Mechanicals 2
Michel Part Numbers Mercedes W116 2
Styria Peterson Museum Part 1 Websites and Links 3
Styria Midnight Express Part 1 Websites and Links 4
Styria Nothing but the best - Part 1 Websites and Links 0
260ebenz TG Africa special part 1 Talking Torque 9
Styria Hydropneumatic Suspension - Part 1 Articles 11
WGB Automatic Transmission Manual Part 1 Technical Information 1
Des Mercedes-Benz And McLaren To Part Ways In Formula 1 World Championship Motorsports 2
R Grille part wanted for my '77 280SE Gumtree/eBay/Facebook Listings 4
abl567 My M-100 Rally, Part 3 Mercedes W108 and W109 5
abl567 Injection pump replacement. Part 2 Talking Torque 3
Des Launceston Auto Museum PART 2 Talking Torque 1
abl567 My M-100 Rally, Part 2 Mercedes W108 and W109 17
abl567 My M-100 Rally, Part 1 Mercedes W108 and W109 26
J Euro 6.9 front molding part number? Exteriors and Body Repairs 31
B Heater hose part number..... Mercedes W116 1
Michel Part number Mechanicals 11
OzBenzHead body panel part numbers Exteriors and Body Repairs 2
