At this stage, I am not planning to remove the head. I just want to try to find the cause of the lack of compression in the two rear cylinders on the right bank. Valves seem OK, so I am guessing it is the head gasket. I have essentially zero in number 4 and about 80 in number 3. I would do a leak down test on it, but first I need to relocate the car so that it is not blocking anything, then I can start to pull various pieces off, such as the radiator so that I can get to the crankshaft nut and turn the motor over to TDC. Damn hard with everything in place, and impossible to lock the crankshaft for the leak down test. I will have to in due course, but will gather all the parts first, then attack it later. I just want to see what is going on first and checking the torque is one of them. Yes, the brake booster will need to come off. Will try to avoid the steering box, but if it has to, it has to.
It was the white one that we did the head gaskets, timing chain, valve guides, chain guides, torsion bar mounts, etc. etc. I will likely do the same with the red one.
