280SL W107 flasher can location
More threads by Terqel
Terqel
MELBOURNE
Hi all, I am new at this, my indicators are working fine but I can't hear the Can working and would like to change it over. Can someone tell me where it is located under the dash and how to identify it.
thanks
Hi Terqel, unless you enjoy being a contortionist leave well alone. A new unit, with pretty well integrated circuitry to the rest of the system, will more than likely set you back at least a hundred if bought locally. Besides, a new one may not be significantly louder - if at all.
If you must feel the need to replace it, move the seat back as far as possible, and you will also need to remove the knee padding as well as the air distribution panel.
Then, carefully and gracefully slide your self under the steering wheel (head first, of course), place your back/backside close to the front edge of the seat, and wrap your legs firmly around the head rests, and ensure that the brake pedal is just, and constantly, touching the side of your face. This is one of those jobs that I describe gleefully if others are insistent on doing it. All in good humour, of course. Regards Styria
T
Terqel
MELBOURNE
thanks for that info, I knew there was a good reason why the previous owner left it.
Styria is correct again!! One of the joys of driving a well-engineered car like this is that the blinkers are near silent. No annoying noises to distract. A new canister will probably not make much difference unless you find a compatible one from another make that uses a louder unit.
Benz-Boy
Benz-Boy
I believe MB have changed their tune.
The current s-Class has quite a noisy canister now
Michel, is there an extra price tag attached for the sound ? :D I reckon even the $100.00 odd quoted for the unit some two to three years ago was more than lukewarm.
Incidentally, there are different types of units used by Mercedes - some have a tiny motherboard that just cannot be fixed - well, at least I can't do it. However, if you're lucky you may have a unit with conventional points - as long as you know how to open the unit without destroying it, you can clean up and adjust the points and, hey presto, it will work again. If you've just saved a hundred, that's a great feeling. Regards Styria
Safety regs have made the increase in noise necessary. I don't like the new S Class anyway - and yes, I have had an extended drive of one. It was competent but without spirit. A sign of growing age, I guess. :rolleyes:
Benz-Boy
T
Terqel
MELBOURNE
many thanks for the feed back. My inlaw has a new S class and I agree it is hard to get excited when driving it.
regards
S KJET EFI conversion - 280sl Mercedes R/C107 3
260ebenz Jerry Seinfeld driving a 280SL Mercedes Mercedes W198, W121 SL and W113 0
S Air con. problem 280SL 107 '81 Mercedes R/C107 5
260ebenz Shannons 1968 280SL Convertible Gumtree/eBay/Facebook Listings 3
Styria 6.3 engine in 280SL Pagoda Mercedes W198, W121 SL and W113 3
T Workshop Manual 280SL 107 Mercedes R/C107 2
T Mercedes 280SL 107 Mercedes R/C107 8
grant v A pic of my 280SL Mercedes R/C107 5
motec 6.9 Will never buy a W107 Mercedes R/C107 20
Oversize New W107 FB Page Websites and Links 1
260ebenz Something for W107 fans Mercedes R/C107 6
6.9forever R/C107 not W107 Mercedes R/C107 3
motec 6.9 W107 Wide body Mercedes R/C107 0
Styria Tribute to our W107 Websites and Links 0
WiSeGuYY UTE from w107 slc Exteriors and Body Repairs 13
Oversize The best W107 video??? Motorsports 12
garrye w107 custom exhaust Mercedes R/C107 18
motec 6.9 W107 Mercedes R/C107 3
motec 6.9 w107 with m120 Mercedes R/C107 1
motec 6.9 w107 big block Mercedes R/C107 0
Oversize W116 & W107 pics on Youtube Websites and Links 2
T W107 Heater/Air conditioning Mercedes R/C107 19
garrye W107 SLC Side skirts Mercedes R/C107 14
T W107 Door Strap Mercedes R/C107 5
S Wanted:W107 Convertible Mercedes R/C107 18
Eagle Bill W107 Flasher canister Mercedes R/C107 2
S w116 parts on a w107 Mercedes R/C107 3
T W107 SL 280 seat belts Mercedes R/C107 6
T hardtop SL W107 Mercedes R/C107 3
C Which W107 model? Mercedes R/C107 14
B Wtb: W107 sl parts Mercedes R/C107 0
J W107 Repairs etc link. Mercedes R/C107 0
smueller99au W107 Diff Interchangeable with which model? Mechanicals 3
smueller99au W107 350SLC engine mounts Mechanicals 14
J W107 Subframe Recall Mercedes R/C107 3
J Keyless Entry for W107! Mercedes R/C107 3
SELfor50 M117 Extractors - For W107 Engine Bay Gumtree/eBay/Facebook Listings 8
Des The daddy of all W107's Mercedes R/C107 33
