Removal of 6.9 Master Air Cell
This is probably one of the easiest jobs to carry out on a 6.9, but it pays to know your way around procedure and tool wise.
First off, I disconnect the height adjustment cable and jack up the front of the car - be sure to place suitable stands under the car to support its weight. Then move the adjustment disc on your distribution valve to the "Repair" position as per photograph.
MechanicalKnowHow003.jpg.
You may/may not require the following tools:
30mm Open End spanner to loosen (only) pressure switch on top of Air Cell.
It cannot be unscrewed completely, and that requires disconnection of the wire from the rest of the system. That only creates hassles.
11mm claw spanner for one of the hydraulic lines.
11mm 'claw' socket spanner for the other hydraulic line.
Normal, short 11mm open end spanner to further undo both hydraulic lines as it is too awkward to further use the claw spanners - they are used strictly to 'crack' the retaining nut.
13mm socket with 'flexible' extensions, and last but possibly not least, a jumbo size 'breaker bar' in case of some stubborn wheel bolts - as can happen when tyre outlets use the 'rattle gun' method of tightening the bolts which happens more often that you'd think. In a situation like that, you could be hard pressed to undo those bolts.
Illustration of application of tools...
Yes, slotted disc rotors are available for our 116s....
You are now ready to unbolt the unit with the help of the small 13mm socket and 'loose' extensions and unscrew the body of the unit from the warning light pressure switch. Hope this helps with your next job. The master cell, whilst not affecting ride quality, is instrumental in maintaining pressure, and holding it, to the rest of the system. It will also prevent the car from 'sinking' when parked overnight. Regards Styria
styria,
thanks for the nice illustrations. Removing the master cell ought to be an easy job - and so I was reckoning on 20 minutes for the webasto-pre-heater project car I'm sorting out for another guy. Turns out one of the 11mm fittings was rounded off previously, and after a great deal of effort I resorted to visegrips to remove it, in the process totally writing off the fitting. (I have now removed the entire line, which runs under the front bumber and terminates under the battery tray, and I have replaced it). Once I was over that hiccup I thought it would be plain sailing, but guess what - one of the three 13mm retaining nuts that secures the air cell was rusted fast onto its stud - and the welded on stud tore free :mad: - result - I had to remove the front valance etc to deal with the stud from behind. So a 20 minute job became a couple of hours.....
When I was contemplating the purchase of my "trusty rusty", you warned me about the misery of rusted fasteners and fittings on euro cars. And true enough, trusty rusty has given me some headaches in this regard, but nowhere near as bad as this dark blue car.
S Paintless Dent Removal Exteriors and Body Repairs 1
H Igntion Barrel removal Technical Information 14
Oversize Rust removal by electrolysis Exteriors and Body Repairs 1
WGB Instrument Cluster removal 101 Articles 3
mrkozzy Ignition switch removal Interiors 4
L Dashboard Removal? Interiors 4
L Power Window Removal Technical Information 1
L Sunroof Frame Removal Technical Information 1
Styria Removal of sunroof frame Interiors 5
Styria Removal of Instrument and Switch Panel Interiors 10
Styria 6.9 removal of heads Mechanicals 32
s class Paintless dent removal Exteriors and Body Repairs 4
s class Att Lukas : ceiling trim removal Interiors 5
L W116 Sunroof Removal for Dummies Technical Information 42
WGB Right side axle shaft removal in a 6.9 Technical Information 7
s class 6.9 sump removal Mechanicals 8
SELfor50 Removal of A/C & Cruise Control Mechanicals 6
motec 6.9 Saoutchik a master coachbuilder Talking Torque 1
Styria 6.9 - Brake Master Cylinder Mechanicals 16
S Air Bags Articles 5
S Air Con mystery Articles 24
Oversize Cold air intakes & intercoolers Technical Information 0
A Air conditioning parts Mechanicals 6
S Seat Air Bladders Websites and Links 4
c107 electric air con Interiors 3
A Air con drain Mechanicals 3
S Air Bags work ! Exteriors and Body Repairs 11
S Air compressor Gumtree/eBay/Facebook Listings 0
Oversize Restrictive Air Filter Assemblies Mechanicals 50
260ebenz Air con re-gas Talking Torque 34
motec 6.9 Red Dot Lemforder air cells Gumtree/eBay/Facebook Listings 2
motec 6.9 wanted 560 twin air cleaner Mechanicals 23
