Need help for w109 016 300sel/8 6cyl
More threads by marie_70
marie_70
marie_70
Paris FRANCE
Some more parts:
injectors lines / intake manifold / headers / air valve control / anti freeze device / compressor / power steering tank / injection pump.
marie_70
marie_70
Paris FRANCE
Lets have a look under:
As you see this is completly free of rust, there is some spots that needs to be brushed and treated with some phosphate primer and touch-up
paint here and there. what a luck !!!
CraigS
Craig, beautiful workmanship on those Pistons. Tell me - from what I seem to recall, you did have some issues with that engine in your 300. Did you manage to address the problem ? BTW, I suspect that the car Igor in France is working on, is more than likely the M130 six cylinder 280 engine, rather than the "old" original M189 unit. Regards. Styria
Waiting on RonB to have space in his workshop to pull it down. The noise is in the valve train. Bottom end is as solid as a rock.
marie_70
marie_70
Paris FRANCE
The interior part seems ok, let's check that.
carpets and seats should be cleaned up carefully in the next days, will see how it goes.
That job took a big 60hrs time... and no dragging around at all if you see what i mean, but all came out in rule of Art, without breakages (very very lucky on that one)
Best regards from France
P.S: Olivier pop around yesterday to say hello, so happy having a Australian guy around... really glad to see him.
Igor
marie_70
marie_70
Paris FRANCE
As the car needs to move to a other storage place (in door) a custom made emergency suspension ply wood buffers for the rear side are being made we should try that tomorrow.
Philippe
France
Salut Igor,
Bravo pour ce super boulot et ton sens de l'organisation inégalable !
Ca fait plaisir de voir que l'auto malgré les années à l'air très saine...
On peut vraiment parler d'une bonne base de restauration.
Je suis très impressionné par les cales maison !!
On à hâte de voir la suite du programme
Désolé de parler en français but my english is so bad ;)
Bonsoir à tous nos amis australien depuis Paris et merci pour ce super forum
Best regards
Philippe
No Problem Philippe, we have a couple of French speakers here including my good Wife. But we don't understand "Cale" A miss print perhaps ?
Meilleurs Voeux
Sean
Best regards
Philippe
Bonjour Philippe et bienvenu sur notre petit Forum.
Je suis un des rares Francophones ici, donc pas de probleme pour expliquer et traduire.
Sean,
Cales (plural) normally means chocks (for stopping brakeless cars from moving), however in this instance I believe Philippe means the wooden 'blocks' that Igor had made for the suspension.
Again, welcome to our Forum.
Michel, from Sydney ;)
marie_70
marie_70
Paris FRANCE
Hello Craig,
I am a bit late for the answer, sorry about that.
yeah this pistons sets are really impressive and looks Top.
As Styria says the engine that feet that w109 016 mid 1969 year is the M130 2.8l, the same one that feet the 280SL "PAGODE" if i am not wrong.
Where did you order these custom made pieces of Art ?
Regards
igor
marie_70
marie_70
Paris FRANCE
Actually, i order those wooden blocks (cales) from our mate Jérôme that is good at doing that sort of emergency engineering solutions.
He is our genius out here.
jerome-paillet.fr/design/
marie_70
marie_70
Paris FRANCE
after a first test set we realized the need to make a bevel for proper seating, Jérôme recut the outside bottom corner at 45° to avoid the weld bead
the result is now acceptable to move securely this heavy baby.
marie_70
marie_70
Paris FRANCE
I had them made by a US company and I hold the right to them.
Hello Graig
This is quite understandable, my question was just in case ...
Thanks anyway for the clarity
Regards
igor
J Not 116, but need help cleaning alloy inlet manifold Exteriors and Body Repairs 11
B Replacing Spings with Foam - need help from one of Melbourne's gentlemen Interiors 24
E REALLY... REALLY Need HELP for W108 280SEL 3.5L Idle Problem Mechanicals 8
E Need HELP on W116, 280S Rear Differential Parts...THX Mercedes W116 5
J Need Hose ID/Part Number Mechanicals 4
Oversize Anyone need some Pentas?? Gumtree/eBay/Facebook Listings 6
260ebenz 6.9 they need saving Mercedes W116 16
Andrew280SEL An old W114 280 in need of some good ol' TLC Mercedes W114 and W115 26
Michel Need Steering Wheel Gumtree/eBay/Facebook Listings 7
Des This is what you need in your life Talking Torque 12
Des This is what you 6.9 guys need Gumtree/eBay/Facebook Listings 2
B 450SE/M117 lower sump gasket - does it need sealant or not? Mechanicals 10
abl567 W202 help in Melton area, VIC Mechanicals 3
S Help Articles 2
BenzBoy Help needed please. Technical Information 17
s class help with 722.002 trans question re K2 Technical Information 3
T HELP! Which m110 engines are K Jet that fit the 280 SLC Mechanicals 12
L Help - W140 Battery Mercedes W124, W201, W140 and R129 19
450SE Help required - engine cutting out Mechanicals 15
Styria Right back door jammed shut- HELP Exteriors and Body Repairs 22
BenzLover Tech help please. Mechanicals 1
Michel Looking For Help Swapping Radios Mechanicals 10
grant v Please help save the East London Grand Prix Circuit - South Africa Motorsports 1
s class M117 timing chain tensioner help Mechanicals 10
c107 W108/W109 early and late headlights Mercedes W108 and W109 4
c107 W109 6.3 vs Daimler Double Six S1 Road Tests 12
260ebenz Something for the W109 owners Mercedes W108 and W109 0
260ebenz Interesting W108/W109 production figures site Mercedes W108 and W109 2
smueller99au 300SEL 3.5 (W109) for sale in WA Gumtree/eBay/Facebook Listings 0
D Problem with 3.5 w109 Mercedes W108 and W109 2
w114/5EST w116 parts to w109 parts Exteriors and Body Repairs 0
OzBenzHead WTB (or otherwise legally obtain): W112 / W109 air suspension valves Gumtree/eBay/Facebook Listings 3
