M117 450 - 370bhp
More threads by WGB
The October 2008 edition of Mercedes Enthusiast arrived in the mail yesterday and there is a short article on a 107 Coupe prepared by AMG which appeared at Monza on March 26 1978 for the European Touring Car Championship - 3rd on it's first outing.
They lightened the car from 1,630 kg to 1,225 kg and the story says "AMG increased the power of the 4520cc V8 engine from 214 bhp to 370 bhp"
Not a lot of detail and it looks like the present restored car now has one of the 1980 Rally car engines putting out 320 bhp which was presumably a 5.0 litre Alloy motor.
The bit that caught my eye was that they state AMG got 370 hp from a 4.5.
Others here may know more about these track cars vs the better known rally cars.
Hi Bill, as you quite rightly state, the rallye cars are better known than any track car. However, we might just be lucky in perhaps Des and/or Michel being able to dig up further information. Regards Styria
SELfor50
Capitown
Hey Bill, are you able to scan and post the article by any chance??
I'm guessing they did all the usual suspects first.. Bore, CAMS etc.. Then maybe injection. That's a sizeable increase though!!
SELfor50
Capitown
Sorry Bill.. i don't get any version. :(
And chance you could e-mail me an 'archiveable' sample?? ;)
Cam.
Hi Cam,
I have tried to send you an e-mail but the format available through the site does not allow me to send a file. When I used the e-mail setup my system hangs so will send you a PM with information.
The colour PDF runs to 4.8 megs.
Damn shame this thread was never finished. RIP
Well that video provides the answer to Dr. Bill's question... the gauge to the left of the tacho is a boost gauge.
[Edit, for clarity given what I said later] It isn't. It's an oil pressure gauge. I didn't realise how low the m116/7 oil pressure spec was until I did more engine research. Turns out 60s german v8s are almost nothing* like 80s Japanese turbocharged wankels...
*their high-functioning dependence on many litres per day of precambrian fern extract aside.
In fact, pausing the relevant shot:
Can be taken as an indication of a 6200-6400rpm redline and 2.2-2.3kg/cm^2 target boost pressure, since they've clocked the gauges for "what you want to see" being needle-at-12-o'clock when the car is vibrating too much to read the scale.
Of course that could well be spurious, and just some restomodder trying to make it look cool, but assuming benefit of doubt thems the numbers.
32psi is a very respectable boost number on a big engine, even in today's 2000+hp dyno-queen tuning world.
[Edit] did a bit more googling, which I should have done earlier. Didn't realise the series was a full homologation category, and AMG couldn't even run their "normal" 5+L engines as a result, nor the 5 speed they offered. So it wouldn't have been boosted. As far as I can see that car in the video is the one that was for sale ex South Africa some years ago, which was listed with a manual box and 5L engine, so no longer in its "original" guise. But info seems really scant on the interwebs. What few articles basically rehash each other, even in german. No engine shots. Certainly very little period photography... 6500ish redline mentioned though, so at least there's that...
Does anyone have a copy of the mag mentioned at the start of this thread?
Hmmm I’m still searching for the article! Doesn’t seem to be in this one!
Could be this one, but I can’t see the month or year…
Assuming it’s the same car in the mag, this is how AMG achieved the hp increase…
And not this much later TT tribute:
No the intake is split into 2 plenums with a TB each. The headers look pretty wild
So doing some very basic math using % hp vs capacity the following theoretical increases could apply if you made the same vintage mods to different engines:
370hp from a 450cc
459hp 560
566hp 690!
If you do the same based on the AMG SEC:
454hp 500cc
510hp 560
628hp 690!
If you base it on % hp increase Std vs competition (73%):
519hp 300hp 560
495hp 6.9 Euro
431hp 6.9 US
460hp 6.9 AUS!
Imagine that (based on 70/80s tech)!!
Basing it on the Red Pig:
420hp 6.8
391hp 6.3!
The 6.3 is a little different since the std intake manifold was similar to the race version, whereas the std 450/560/6.9 intake was very different to the race version. Obviously the modified exhaust helped.
So the big question is what can be achieved with today’s tech & I aim to find out…
Well I’m no closer to finding the article, but I did buy the April 2009 edition which featured this stunning 300SL! Pity it’s just a standard M103 and not an AMG modified M117…
Well I still haven’t found the article, but I discovered this pretty accurate replica being built in Finland!
Oversize C111 Epic Soundtrack M117 TT Motorsports 6
Oversize Sbarro Twin Turbo M117 Talking Torque 0
Oversize Looking for a M117 5.0?? Gumtree/eBay/Facebook Listings 3
Oversize M117 Burnout Websites and Links 3
motec 6.9 Wanted M117 560 throttle body Gumtree/eBay/Facebook Listings 11
motec 6.9 300SE Coupe with 5.0 M117 Gumtree/eBay/Facebook Listings 8
mercdz M116/M117 D-Jet injectors Mechanicals 0
motec 6.9 Gemballa w126sec m117 6.9 Talking Torque 2
Tony66_au M117 wont idle Mechanicals 4
SELfor50 M117 Piston Gumtree/eBay/Facebook Listings 0
Styria What spark plugs for the M117 and M100 Mechanicals 19
Des M117 Tuning Motorsports 7
SELfor50 M116 Heads on an M117 Mechanicals 17
s class M117 timing chain tensioner help Mechanicals 10
SELfor50 M117 Gearbox Gumtree/eBay/Facebook Listings 4
SELfor50 M117 Engine Gumtree/eBay/Facebook Listings 3
SELfor50 M117 Extractors - For W107 Engine Bay Gumtree/eBay/Facebook Listings 8
SELfor50 LS1 inspired M116/M117 Engine Overhauls!! Mechanicals 1
B 450SE/M117 lower sump gasket - does it need sealant or not? Mechanicals 10
A New ignition key for 450 sl Mercedes R/C107 4
M 450 SEL repaint Exteriors and Body Repairs 5
Oversize A Heavily Modified 450 Websites and Links 3
Oversize Interesting 450 at Hanging Rock 2015 Mercedes W116 2
Styria 6.9 with 450 differential Technical Information 30
Styria 350/450 Exteriors and Body Repairs 6
A new find 450 sel Exteriors and Body Repairs 11
braminator123 Uk 450 sel 6.9 Gumtree/eBay/Facebook Listings 7
Michel 78 Euro 450 SEL 6.9 AMG in the USA Gumtree/eBay/Facebook Listings 10
garrye 450 slc pics Mercedes R/C107 3
4 450 SEL injector service cost ?. Mercedes W116 4
300SDude 1978 Mercedes-Benz 400-Series 450 SEL AMG Gumtree/eBay/Facebook Listings 26
4 450 SEL aircon fan improvements needed Mercedes W116 3
300SDude 79 benz 450 sel v8 Gumtree/eBay/Facebook Listings 12
garrye 450 slc breaking down under acceleration Mercedes R/C107 6
Nudge 450 with no spark Mechanicals 5
L 450 sel '77 HYDRAULICS Mercedes W116 1
SELfor50 450 SLC - Engine Conversion Mercedes R/C107 7
SELfor50 450 SE 6.9 #2 Panzer Jager Mercedes W116 22
J What ratio diff do most 450 116's have Mercedes W116 13
TJ 450 TJ 450's 6.9 Pics Mechanicals 7
