K Jetronic idle 107 280 S.L.
Not quite so simple as it is made out to be.
At times the idle speed changed both cold and hot. Not a lot, but it should not be so.
The Air flap opened and closed ok .. but the was a build up of krud around it, and looking down inside at the Butterfly , it had a build up of carbon like krud around the edge. Circuit Board cleaner, cleaned it all up ( I didn't have anything else ) Now a nice steady idle cold at 1000 RPM. So hot should be ok at around 750 RPM
(providing the Auxiliary Air Valve is doing it's job)
CraigS
I'm not sure if you were asking a question or just making a comment, but the auxiliary air valve can be taken apart and also cleaned, or cleaned internally (ultrasonic) and adjusted by lightly tapping to move the top further into the housing. Over time, it will lift out of the housing body and as that occurs, the effectiveness is reduced.
PROBABLY a comment Craig, perhaps it will help others. Cleaning inside the Air Flap would have been the last thing I would have thought of.
I have cleaned and adjusted the Air Valve . Under the inlet manifold on the 110 6 cyls. cars. Not for the faint hearted .
Can only be seen from under the wheel arch, and removed /refitted by Braille !
A K jetronic service Mechanicals 2
S K Jetronic O Rings Technical Information 4
Styria K- Jetronic explained Mechanicals 0
S componant K Jetronic Mercedes R/C107 6
Martin280s Troubleshooting D-Jetronic Mechanicals 19
Tony66_au M117 wont idle Mechanicals 4
Tony66_au 4.5 base idle settings and how to... Mechanicals 7
Michel Idle on a 6.9 Mechanicals 4
TJ 450 6.9 Lumpy idle Mechanicals 15
c107 107 107's across the Harbour bridge Car Show Photos 5
c107 A couple of 107 reviews Road Tests 4
Oversize Very nice 107 SLC Mercedes R/C107 1
M 107 Mercedes R/C107 2
CraigS I have joined the 107 club ! Mercedes R/C107 14
S dash covering 107 SL Interiors 24
S SL 107 safety Mercedes R/C107 0
S 107 Imports Mercedes R/C107 6
S Sale of 107 Mercedes R/C107 4
S hood Pad 107 Mercedes R/C107 3
S wind deflecter 107 Gumtree/eBay/Facebook Listings 0
Styria 107 Meet in Holland Talking Torque 6
Styria Unhappy 107 - SL Exteriors and Body Repairs 11
Styria Fantastic 107 site Websites and Links 0
Styria Useful 107 information Mercedes R/C107 0
A 107 break upgrades Mercedes R/C107 10
Styria 107 website - northern source Websites and Links 0
