Hydropneumatic Suspension (HPF) Series 2
Here’s more of the S1 on delivery...
Interesting order. Most of the factory delivery cars still have the ordering dealer, this looks like somebody ordered the car directly from the factory?
FIN WDB12603722017724
Model 500 SEL
Engine 117963 22 005450
Transmission 722311 02 174349
Order Number 0 0 402 00024
Order Location TOURISTS (WITHOUT USA)
Interior LEATHER - GRAY (238)
Paint 1 BLUE-GREEN - METALLIC PAINT (877U)
Code Description
221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE
222 RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
223 REAR SEAT BENCH ELECTRIC ADJUSTMENT
251 BECKER RADIO MEXICO CASSETTE, FULL STEREO, ELECTRONIC
430 HEADREST IN THE REAR, LEFT AND RIGHT
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
470 ANTI-LOCK BRAKING SYSTEM (ABS)
487 HYDROPNEUMATIC SPRING SUSPENSION ALL AROUND
531 AUTOMATIC ANTENNA
543 SUN VISOR WITH VANITY MIRROR, ILLUMINATED, LEFT AND RIGHT
570 FOLDING ARMREST, FRONT
580 AIR CONDITIONER
592 HEAT-INSULATING GLASS, ALL-AROUND, HEATED REAR WINDOW PANE, BAND FILTER
602 CUSTOMS LICENSE PLATE FIXTURE
615 LAMP UNIT, ASYMMETRICAL L.H. TRAFFIC, AND FRONT AND REAR DOOR COURTESY LAMPS
660 80 LITERS OF FUEL
877 READING LAMP IN THE REAR
Mercedes Benz VIN decoded at https://www.lastvin.com/vin/1735zAJ6QL6AmyMQv
Thanks for the VIN search which makes interesting reading!! And it doesn’t reveal the country of origin??
6.9forever
Sunshine Coast
I’ve spoken to the seller previously, but being I don’t need even more spares, it’s hard to justify the significant investment. Hence they’re still for sale! Strangely someone had cut the small hydraulic lines instead of just unbolting them & I don’t even know if they could be replaced easily....
BTW they’re front struts where LH & RH are different. The rear ones are interchangeable. Road freight only & not via AUST Post since they freak out about the ‘high pressure’ cells!!
And the big question is vot tis dis???
Here’s a copy of the wiring diagram which isn’t too complex:
And the location of the ECU which again seems pretty basic so that makes it easier to diagnose and repair
I sold the car a couple of days ago to someone in NSW looking for an engine donor. So that meant I had to get moving & remove all the HPF components including wiring. No small task as I discovered!!
108676DC-E743-4EAD-8132-CBAE08486679.jpeg3A3D67BF-A75D-4AAA-B179-4C86F4B8282A.jpegE0B96C34-89AD-4209-9DC6-7F2B4D38D90D.jpeg
It is obvious to me the system was installed prior to the drivetrain which makes some parts impossible to remove without a full strip down or permanent ‘modification’ of some pipes...
9588275F-5CA3-4C06-B59B-2624CC7D609F.jpeg2B12AEFA-8DFC-4959-98C8-4D07FD5E3A7F.jpegA95893D4-7EEE-40F9-A537-1792885DE14D.jpegD056E781-5F0D-48AF-90B0-C20ED2C4D002.jpeg545F2978-6B56-4406-9675-C30E5581DE29.jpeg
I had to buy a special Phillips bit driver to save 3 of the junction blocks. The block above the rear suspension carrier would’ve been impossible to remove without it; there’s almost zero clearance.
Say hello to my little friend!
65FBA5DA-F8D9-433D-A6B9-6BD82AB813D0.jpeg0B287DB1-3F28-4688-AFD5-7CEDB3DA600C.jpeg6B4279E9-7A91-4020-99F5-BE76E1A39DD3.jpeg1844183A-3A5C-4AFA-BF33-8A2AD6442715.jpeg288FEB81-3D64-4FF5-AE34-4D0AB7BC9E8B.jpeg
Apparently the car originated in South Africa. Strange since it had a Webasto preheater fitted but only parts of it remained... I would’ve saved that too but it was incomplete & a fire risk even when operative.
422769B8-38A4-48C3-A6ED-91F26FC2E970.jpegBFB109C4-2F05-4BF1-90EB-47B5A6DE3903.jpeg9181F0CF-A9D7-4663-AFC4-F4C860DEE417.jpeg
Now to pack it all up properly. Hopefully I’ll get to use it all in the future to upgrade a 6.9 system to the later S2.
Note to anyone intending to pull a system like this apart in the future; hot pressure wash everything BEFORE disassembly!! Not only will your overalls thank you, you’ll use fewer gloves & it’ll be less likely to get contaminants into the sensitive internal mechanisms....
Here’s a pic of the pesky rear junction block which can be seen above the rear subframe. This feeds the rear lower ball joints. You have to be Houdini to get it out in one piece! 🥴☺️
There’s at least 5 pipes that run from the front to back of the car under the RHS. Of the 5 pipes 2 are far smaller and they feed the rear lower ball joints for stiffening & the adjustable link for auto lowering/raising.
BDEC9C42-3146-4610-98CB-309136FE6367.jpegE844D968-1569-47AC-BCF8-295E9CF326F9.jpeg7918D4DF-24F4-4112-94C0-B33698829879.jpeg
Styria Hydropneumatic Suspension - Part 1 Articles 11
Styria 6.9 Hydropneumatic Suspension Articles 4
Oversize Hydropneumatic Strut Top Mounts Gumtree/eBay/Facebook Listings 1
Oversize Hydropneumatic Gas Cell Package Gumtree/eBay/Facebook Listings 14
4 450SEL suspension and injector parts Mercedes W116 18
motec 6.9 Mercedes launch worlds first seeing suspension Articles 15
S hydraulic suspension Mercedes W116 4
Styria 6.9 Suspension Height Articles 0
Styria Suspension issues - Gleaming Beauty Mechanicals 5
Oversize Suspension repair kit Gumtree/eBay/Facebook Listings 1
CraigS Hydro / SLS suspension fluid Mechanicals 3
Oversize McLaren MP4-12C Suspension Technical Information 4
Styria Rebuilding 6.3 Suspension Compressor Mercedes W108 and W109 0
B 6.9 suspension issues Mechanicals 15
M Hyrdo suspension parts Gumtree/eBay/Facebook Listings 0
MercedesMike 6.9 suspension not pressurizing Mechanicals 3
Oversize 6.9 Suspension Reconditioning Mechanicals 2
Oversize 6.9 Suspension blocks Mechanicals 28
MercedesMike 6.9 Suspension Blocks Mechanicals 4
oscar Those W126 AMG suspension parts..... Motorsports 1
Michel Mercedes Benz AMG Suspension kit to suit W116 Gumtree/eBay/Facebook Listings 6
Styria 126 suspension "blow - up" Mercedes W126 0
abl567 Suspension Fluid on fleabay Gumtree/eBay/Facebook Listings 4
B WTB: 6.9 hydro suspension tank Gumtree/eBay/Facebook Listings 9
B 6.9 suspension conversion Mechanicals 11
Michel Rear Suspension Problems Mechanicals 63
D w123 diesel, rear suspension Mercedes W123 3
Des 450SEL 6.9 suspension blocks Mercedes W116 19
J 6.9 suspension modification Mechanicals 0
