The vacuum water temp valve is either open or closed.... Lots of enquiries ( no result ) to see if anyone has come up with a modification to allow a modulation of the hot water flow to the Heater . i.e., to reduce the flow and control the temperature of the Cabin. .. Been in the to hard basket for a long while, as it was not a priority. The rest of the heat and Air Con system controls seem to work ok ..... I guess the only way is to be able to vary the vacuum to the valve , but how ?
The only way I can have some control is to open all the cold air vents at dash level, to reduce the flow to the foot wells with the fan off. I run an 82 % thermostat and engine temp rarely rises above 85%s.
