Seized rear brake caliper
Sean, the word is hygroscopic . And I don't believe changing brake fluid every 2 years is overkill, I have seen the results, no master cylinder failures, no leaking / seized calipers, no blocked brake hoses.
Peter, please don't tell little Wifey that I can't spell... Her with a PHD in English. She usually vets and corrects most things I write.
Also, tell me something about the chipping system you have. When you Flash the ECU is it reversible , before having a Warranty visit to the Dealer?
My Tuning Box has been seized by German Customs on a technically , I sent it back to fix a malfunction. They probably want Money , the origin of the Unit is Germany and as a used malfunctioning item is worth 0 euros. I told the supplier I am writing it off. Not worth the hassle of dealing with Customs from afar.
E200K Rear foot-rests Interiors 17
