Engine weights
More threads by Mercules
Mercules
Spiltting lanes
Can anyone tell me how much the W116 engines (280,350,450,6.9) weigh?
If you suspect I am in the process of conjuring up my next feat of mechnical bastardry... you would be correct. :rolleyes:
Hi Cameron, I don't know if anyone would be able to tell you. I have both a 450 and 6.9 engine at my premises, but have no means to weigh them. The 6.9 is a huge lump of cast iron, and I am only guessing that you'd be looking at 400 kgs. for a complete engine. The 450 would weigh about 80 kgs. less - but, it's all guesswork. You must let me in on any secrets that you may be harbouring.:cool:Regards, Styria
Doing a bit of checking on the net I came up with this....
Don't know if it will help you much.... but it's better than nothing
Found this link and it could prove useful. I've copied/pasted the Mercedes section. Weights are in pounds.
http://www.gomog.com/allmorgan/engineweights.html
Engine weight pounds ref. comments
Mercedes SOHC V8 alum. 452 (2)
Mercedes SOHC V8 iron 540 (2)
Mercedes 5.6L V8 467 (57) 1987
Mercedes OM 615 Diesel 447 (16)
Mercedes M291 flat-12 374 (66) with starter, alt, exh, no clutch
Mercedes 2.8/4.2 V6 331 (127) 1997, SOHC 3V, "shipped for assembly"
Mercedes inline six 441 (127) 1995 and back
Mercedes 500I V8 305 (46) 1994 pushrod Turbo Indy motor (Penske)
Mercedes/Ilmor Indy V8 273 (57, 60) 72 deg V Turbo Indy motor
Mercedes/Ilmor DOHC V8 280 (89) 1995 IC 108 model, no clutch
Mercedes/Ilmor IC108C 280 (130) 1996 DOHC V8
Mercedes 3.2L V6 330 (141) 1997 SOHC, 90 deg, 3 valve
Mercedes 5.8L V12 490 (143) 1997, 3 valve
Hope that helps
Hi Michel, those are interesting figures, I was surprised at the relatively small difference between cast iron and alloy V8's. By the look of things, my "here's looking at you kid" estimates appear to be somewhat exaggerated.
Interesting reference to the flat V12. I wonder if that engine was fitted to the E-Classes that were raced in the German Touring Car championships ? I also see a reference to three valved engines - in the very early '90's (I think), Mercedes in one of their brochures made geat play of the fact that there was no need for 4-valve heads as they lacked torque and 3's were perfectly adequate. Today's engineering seems to indicate otherwise. So, what would a 6.9 weigh - all up, it would have to be close to 330 kgs. with all ancillaries fitted. Regards, Styria
S Same Engine Articles 14
S Engine swap Mechanicals 7
